Center pin resistance check getting 00.0 [resolved]
Kozic · 1929
Offline Kozic
on: January 10, 2017, 07:14:48 AM
So all the other resistance checks are fine, but the last one the center pin. both led banded ends are going to the center and and facing up all the joints look and feel good. even the top inner volume pot looks good. Any advice?
« Last Edit: January 10, 2017, 10:39:02 AM by Caucasian Blackplate »
Reply #1 on: January 10, 2017, 07:35:20 AM
Center pin of what?
Offline Kozic
Reply #2 on: January 10, 2017, 07:50:38 AM
The 9 pin tube socket it was the only "center pin" in the manual.
Reply #3 on: January 10, 2017, 07:54:14 AM
Center pin of 9-pin socket should be zero. It is not called out in the resistance check. Center pins of the RCA jacks are listed in the manual, and must be ~100K.
Offline Kozic
Reply #4 on: January 10, 2017, 08:02:21 AM
Bah you and your knowledge.... ;)
All is good THANKS man.
Edit; I just rechecked my manual and the RCA jack center is referred to as the solder cup.
« Last Edit: January 10, 2017, 10:28:58 AM by Kozic »
