Eros is humming
Why1504 · 9854
Offline Why1504
on: February 01, 2017, 11:36:16 PM
I have a new build.  probably has 100 hours of burn in.  I noticed a yesterday that I had a hum.  It is coming from the Eros.  There is a minor hum when it is powered off and is more pronounced when powered up.
I have no idea how to proceed here.  Please help.
Reply #1 on: February 02, 2017, 08:44:36 AM
I would start with a check of the voltages.
Offline Why1504
Reply #2 on: February 04, 2017, 12:50:04 AM
got to the bench this morning.  on the A side the of the chassis,  A side of the C4S card, when powered up, the A side LEDs light, B side  LEDs do not light.  After about 4 seconds the A side LEDs go out.
Offline Why1504
Reply #3 on: February 04, 2017, 10:12:00 AM
I would add, that all of this was operating normally when I did the testing at the conclusion of the build.  Eros has about 100 hours on it.
Reply #4 on: February 06, 2017, 09:29:18 AM
Why don't you post your voltages, noting the ones that are not to spec. That is always the place to start. It could be that you have a bad connection that has shown itself after a few heat cycles, and voltages might help us isolate where the problem lies.
Offline Why1504
Reply #5 on: February 11, 2017, 04:43:21 AM
Finally got a chance to catch my breath this morning ( I run a company and the last two weeks have been insane.  Today I leave on travel for a week, back Friday and Sat of next week then gone for two more weeks)  Here are my voltages:
                  A                       B
KREG         .6                      1.77
BREG        7.42                   96.8
OB            221.4                 95.1
OA            220.8                169.7
bA                  0                     0
IA             223.0                 223.9
Thanks for any assistance!!
Reply #6 on: February 14, 2017, 02:56:26 PM
KREG         .6                      1.77
BREG        7.42                   96.8
OB            221.4                 95.1
OA            220.8                169.7
bA                  0                     0
IA             223.0                 223.9
I would suspect you have a broken wire or very loose solder joint in your build somewhere.  It could be the ground connection for the board with all the out of whack voltages.
Offline Sugar Man
    • The Last Honest Lawyer
Reply #7 on: February 15, 2017, 04:37:35 AM
I added the MourQuiet to my Stereomour and wasn't totally happy with the sound.  When I turned it back over to investigate, I had totally forgotten to solder a terminal tab with a bunch of resistor leads.  I could have sworn I double- and triple-checked everything.  Sounded much better after I applied a bit of solder to the oversight.  Good luck finding your problem.
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
Offline Why1504
Reply #8 on: February 15, 2017, 10:56:33 PM
Thanks. I plan to work on her this Saturday.
Offline Why1504
Reply #9 on: March 25, 2017, 04:23:28 AM
After 4 weeks of travel followed by 3 weeks of sickness I finally got in this morning and began doing some serious investigation.  Almost immediately I found a wire that wasn't connected.  Fixed that.
All of the voltages are now in spec.
But, the preamp has now developed a white noise with some thumps that sound much like a dirty album.  the noise is coming out of both channels.  I get it with the turntable disconnected.
HELP!!
Offline Why1504
Reply #10 on: March 26, 2017, 06:08:21 AM
I cleaned up a couple of solder bridges. I know I have a bad joint somewhere.  When I tap on the chassis the noise will come and go.
All of the LEDs are glowing.  I have requested one of my engineers to help me with this next week.
Reply #11 on: April 14, 2017, 10:35:57 AM
You can get in there and poke around with a wooden chopstick to find the joint that is aggravated by tapping on the chassis.
Offline Why1504
Reply #12 on: April 28, 2017, 05:28:08 AM
I found the bad Joint!! Fixed it!!
The rattle is gone.  However, I still have a hum but it only becomes audible at about 1/2 volume which is a significant improvement.
Any suggestions on the hum??
Offline Why1504
Reply #13 on: April 28, 2017, 07:38:16 AM
The hum is still there but with music the sound is fantastic.
I ma guessing the signal is way overpowering the hum.
Reply #14 on: April 28, 2017, 08:23:45 AM
Is the music too loud to listen to at 1/2 volume? If the cartridge has a relatively low nominal output level, the hum can just start to be audible with no signal playing at very high volume settings. That hum would be a soft, sine wave type of hum. If the hum is buzzy that would be a grounding issue, most likely between the turntable and the Eros.
