EMF (?) interference with S.E.X. 2.0
denti alligator · 5011
Offline denti alligator
Reply #15 on: April 20, 2017, 10:24:30 AM
Yes, they are. All plugged into the same power strip. I've got a new strip on the way and will use a GFCI tester tonight to make sure there isn't something wrong with it. But besides that I don't know what to do.
- Sam
Offline Jamier
Reply #16 on: April 20, 2017, 10:43:42 AM
Have you tried a different circuit within the house? You might have a ground connection on that circuit but it could be weak depending on how the house is grounded?
James Robbins
Reply #17 on: April 20, 2017, 11:44:38 AM
I will try that now. This only happens with one particular PC that I use for music. But lifting the ground on that PC doesn't make a difference. Only the ground on the SEX amp does. Could there be an issue with the wiring of the SEX? How could I determine that?
- Sam
Reply #18 on: April 20, 2017, 11:58:20 AM
Just tried a different breaker. Same noise.
Same noise is audible through Stereomour and speakers, too, just much quieter.
Since this isn't a problem restricted to the SEX I'm going to start a different thread in the general forum.
« Last Edit: April 20, 2017, 12:23:00 PM by denti alligator »
- Sam
Reply #19 on: April 21, 2017, 08:59:08 AM
So what are my options for removing the ground loop?
http://bfy.tw/BMLX
I'm just mirroring what PJ posted in the other thread you started on this same topic.
