Hum at high volume [Resolved]
shrapnel · 2674
Offline shrapnel
on: February 15, 2017, 12:51:12 PM
Hello,
I finished building my Crack and resistance and voltages checked out great. I plugged it into my Oppo cd player and it sounds just great, but ....
Case 1) I hear hum when the pot is turned beyond 75% volume position. I don't hear this below that level. Also I hear this when no music is playing. I haven't tested the volume beyond 75%. So is this hum normal ?
Case 2) I plugged my computer audio jack into the Crack using a EPA-RCA cable and in this case I hear a hum even at low volume levels. When I remove the cable from the computer I observer behavior as in Case 1. So is this related to the cable ?
Thanks much,
A
« Last Edit: February 24, 2017, 07:08:20 AM by shrapnel »
Reply #1 on: February 15, 2017, 02:00:04 PM
The answer to number 1 is well covered under the Crack FAQ:
http://bottlehead.com/smf/index.php?topic=4295.0
As far as number two goes, what's an EPA cable?
Computers are noisy sources generally, what kind of noise is there with your phone as the source?
Offline shrapnel
Reply #2 on: February 15, 2017, 03:30:36 PM
Thank you for pointing me to the FAQ.
I meant a standard stereo jack to RCA
The noise I hear is a low hum, basically the same hum I hear at higher volumes in case 1.
Reply #3 on: February 19, 2017, 12:51:05 PM
The noise either originates from your computer, or from interference picked up by the cable between your computer and the Crack.
If your computer has a toslink output, an inexpensive external DAC cabled to your computer with a toslink cable will eliminate many common noise issues folks experience similar to what you're describing.
Offline shrapnel
Reply #4 on: February 20, 2017, 07:33:26 PM
You are right, experimenting with other sources it is clear to me that it is either my computer or other electrical interference. Unfortunately it is a MAC book laptop and I don't have TOSLink. I have however ordered a DAC and will experiment with USB.
Thanks for the suggestions.
Offline Tom-s
Reply #5 on: February 20, 2017, 09:13:42 PM
A Macbook normally has a toslink connection.
The 3.5mm audio ouput can be used with a mini toslink connector.
This is the way i use my macbook (Mac mini etc etc) -> DAC.
Offline shrapnel
Reply #6 on: February 23, 2017, 01:22:02 PM
I got a Schiit Modi Multibit in the mix and lost the hum. Thanks for tthe help guys.
