Bottlehead Kits
Crack
Smoke coming from Crack transformer plugging in for voltage test
mightygrey
5398
Paul Birkeland
Global Moderator
Hero Member
Re: Smoke coming from Crack transformer plugging in for voltage test
Reply #15 on:
April 20, 2017, 06:14:40 AM
I would personally remove all the UF4007's and the 220uF cap that goes with them, then start over. That may require a new 6 lug terminal strip.
I still believe that there is a short wired into the amp on that terminal strip that has taken out the transformer, and putting a new transformer in is only likely to confirm my suspicion.
Deluk
Sr. Member
Reply #16 on:
April 21, 2017, 01:22:34 AM
A new transformer and associated parts may well be needed but I would consider returning the current, possibly u/s one, to Bottlehead. Yes it will be a moderate cost for postage Oz to USA, but would confirm the diagnosis.
Bottlehead Kits
Crack
