Intermittend high pitch noise
bergurbrag · 3734
Offline bergurbrag
Reply #15 on: August 16, 2023, 04:20:44 AM
Ok, thank you.
I am still waiting on the diodes so I can do the modification to the ICE.
The intermittent high pitch noise in the right channel is still there. It comes on and ends with a short even higher pitch burst. It ends like if you where turning off the water in a sink, a gradual but a short process. As I have said before this noise is not there when use a different source.
Does this tell you anything or is there something I could do to get an answer to why this is happening and what can be done to fix it.
Please help in fixing this issue.
With regards, Bergur
Reply #16 on: August 17, 2023, 08:46:39 AM
I think it's likely that the diode modification will solve this issue.
Offline bergurbrag
Reply #17 on: August 17, 2023, 09:46:19 AM
Ok, thank you.
Does this modification affect sound quality ?
Reply #18 on: August 17, 2023, 09:54:15 AM
No, it just mitigates noise from sources that may have CPU related earth noise issues.
Offline bergurbrag
Reply #19 on: August 17, 2023, 10:04:22 AM
Ok, thank you again
Offline bergurbrag
Reply #20 on: August 21, 2023, 07:35:30 AM
Did the diode modification and dead silent
Thank you very much for your advice!
Can you be so kind as to explain in a few words how this solution works ?
The amp still has a earth connection ?
I am sending you a picture just to make sure I did it right.
Is it OK ?
Reply #21 on: August 23, 2023, 05:39:35 AM
I'm glad that worked out for you.  Some additional information can be found here: https://forum.bottlehead.com/index.php?topic=11676.90
