Bottlehead Kits => Crack => Topic started by: blackeyeliner on March 25, 2015, 07:03:53 AM
So I've built my Crack with a lot of DIYing on the casing - I made an additional housing for VU meters, installed VU meter board inside the case etc. However, the meter board is powered with external 12V power supply, which is obviously not an elegant solution... Is there any way to get 12V from Crack power supply and not influencing the sound?
How much 12V current do you need?
Very little: 0.1A max, typically 0.08.
If it's that little, you could try adding a voltage doubler to get +12V.
Does the 12v need to be grounded? Does the audio input to the meter board need to have the same ground as the 12v power supply? If so, be sure to remove the heater winding ground before grounding a doubler supply. It may or may not affect the hum level - just be sure to check this.
Yes, it's definitely very little. Unfortunately, I'm not very experienced in electronics, could you elaborate a little more on how voltage doubler could be implemented in a Crack?
12V needs to be grounded.
Audio input uses a different ground other than 12V power supply, they are isolated in the board - as I understand, for the sake of hum. Right now the board is powered with a separate power supply and it does not affect hum in any way.
However, I don't really understand how to make a doubler and how to apply it to the existing circuit yet :) But I am sure that with little help I will be able to do it.
I would do some reading online about voltage doublers, then come back with specific questions.
I understand the theory how voltage doubler works - I understand (or at least I suppose I do) that if I know reliably a 12V point in my circuit, I can add voltage doubler to this point and get 12V not altering the voltage of the circuit itself.
However, it's really unclear to me to which point to hook it up to and what scheme of a voltage doubler to use (my research showed that there are dozens).
A voltage doubler gives you 12V DC out of about 6V AC, but with a ton of ripple. This can be added to the 6.3V winding in the Crack, provided you don't need much current. The ground reference of the winding may have to be removed, but this depends on whether you need a specific 12V ground reference.
It gets clearer. So I hook up a scheme like this:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fwww.daenotes.com%2Fimages%2Ffull-wave-voltage-doubler.png&hash=8030aa1579eed0b61635cabb2f952e19fa318ce6)
to a 6V AC winding of the crack and I get 12V DC which will be pretty ripply, but should I guess work for my purpose of powering the driver board.
In case I don't need a specific ground reference for the audio signal in the power wiring I just use the + and - wires of the 6V AC winding? The board has separate input for audio (left, right and ground reference) and for power (+12V and ground).
If that is right, I need to understand now is where this 6V AC winding in the Crack is and what capacitance I need for capacitors. Everything else seems to be pretty simple.
I am really sorry for my lack of knowledge in electronics, but I am really trying. Big thanks for helping me out with this.
The 6V AC winding is the heater wires. They appear on A4/5 and A9.
Set your meter for continuity, then measure between the ground pad on the +12V pair and a ground pad on the ground reference by the L/R pads. Are they connected?
Just done it. No, they are not - they show around 800-900K Ohms between them.
That's a decent sign that you can add the doubler to the Crack and not move the grounding. I would recommend wiring up the doubler to give +/-6V, which would mean that the grounded terminal on the 6.3V winding should go to the junction of the two caps.
Cap sizes are determined by how much ripple you can tolerate, I'd say start with 4700uf and see how that works.
So it's exactly like it's done on the scheme I proposed (this one - http://www.daenotes.com/images/full-wave-voltage-doubler.png), right? I am ready to go in this case and will do it by weekend.
Yeah, I would put some resistors across each of those caps, 1K ought to be enough, wattage rating isn't particularly important with only 6V across them, 1/8W is enough.
Across - you mean, in parallel? Will do. Just out of curiosity, why is that desirable to do?
It's generally good practice. IMO, it matters more for high voltage circuits, where you really want to know that each cap is seeing an equal amount of voltage.
I made it and - it worked! However, I messed up with polarity while plugging it in and one of the capacitors is destroyed, so I will have to replace it. However, the doubler gave me 13V DC which was pefrectly fine for powering the board.
Interestingly enough, while looking at the board I understood it could be powered with AC, as it has diode bridge on it (and AC IN marking). However, directly hooking up 6.3V AC from Crack to the board did not work - it barely produced enough voltage to light up the backlights, and meters did not work. With doubler however, it works just fine.
Here's how it looks:
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FME0WGlv.jpg&hash=556d32b56a97e6ac99f0cdaa3bb5194f7b0ccfc3)
A terminal strip or a piece of proto board can make that more durable/safe. A 6V winding into a diode bridge will give 4-7V, depending on load and diodes.
So I rebuilt the doubler with a new capacitor. It is weird but it's working perfectly when the sound inputs are not connected to the board, the lights go on, doubler produces it's 13.5V DC, but if I connect the sound input, lights on the board (meters illumination) go off and it starts humming into the sound circuit.
I obviously measured the current flowing through the doubler and with the sound input connected, it's 2+ amperes, while without sound inputs connected, it's normal 0.08A. Is there something I am terribly missing?
Yes, undoubtedly something is very wrong there, but it's hard to know without knowing a lot about the VU board setup.
So you think there's nothing I can do on my own at this point? I guess the board design will be hard to get somewhere. It's pretty simple, but I don't understand how connecting audio can make it draw 2+ amperes, really. At the same time, any external power source makes it run perfectly well.
I just thought that probably an easier way would be to use the fact that the board can be powered with AC (it has a diode bridge on it and a stabilizer afterwards) and just find a very small low power transformer, install it inside the case and power in parallel from the switch...
That's probably a better idea. 12V transformers are very easy to find.
So it appeared that 12V is not enough for this board to function. It was technically working, but it has a 12V regulator after the diode bridge, that needs 18-19 volts DC to output 12V stabilized. I found a small 24V transformer, put it on a small board, drilled a couple of holes in the casing and here it is, working like a charm. The only problem is that the transformer gets pretty hot.
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2F0sbsyDd.jpg&hash=7fc31c605c0d24d155d3984612d0492ba6d8f0a9)
(https://forum.bottlehead.com/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FFQmxFyV.jpg&hash=6f502655312521dc1925c1e5f91d1ac080914b3c)
So to close this up, I ended up installing a radiator on top of the transformer, replaced the transformer with a lower voltage one so it generates less heat. It's still hot, but the rest of the amplifier is the same temperature.
So I guess this is it, it seems to work, spend the day on, like 8 or 10 hours already.
What is the VU board you are using? Most voltage regulators need higher voltage then their output, for example for 7800 series or LM317's they drop out when the source supply is less than 2v above its output voltage so +4v is usually a good target to aim for. Going too high, like feeding a 12v regulator 24v will cause it to run very hot as it has to dissipate the extra voltage.
A hot transformer could indicate the load is higher than the transformers current rating. Generally those small PCB transformers do run hot so its usually a good idea to fit one rated for more current than it needs to supply, assuming you have the physical space.
They have changed the layout of the board since I bought mine, but it's something like this: http://www.ebay.com/itm/2pcs-Panel-VU-Meter-Warm-Back-Light-Audio-Level-Amp-One-driver-board-/121468037573?pt=LH_DefaultDomain_0&hash=item1c480f29c5
You are right, they are using 7812 regulator on this board, and I measured, it does not run very hot in my application. It gets 22V DC input from the rectifier bridge and then regulates to 12.0V. Right now I have installed a 18V AC transformer that is rated for 0.16A, whereas the board consumes 0.8, so fine here.
I then run the transformer outside of the case for several hours to understand if it's overloaded or something - it doesn't get hot at all, like 30-40 degrees maybe 50 tops. Inside the case, hanging upside down, it does get pretty hot, I presume because the overall temperature inside a Crack case is high, everything dissipates a lot of heat. It's been working for a week for me, sometimes 8-10 hours non-stop, with no problem so far.
