Bottlehead Kits => Crack => Topic started by: rogerthatmand on July 27, 2015, 08:21:52 AM
Title: Resistance (ohms) failure
Post by: rogerthatmand on July 27, 2015, 08:21:52 AM
Hey guys, I'd like to get some help. I finished building the Crack but I have some issues with the resistance check (the first step, the ohms).
I have a volt-ohm-meter which I configure to 20K Ohms:
Terminal 6, 10 - gives me 1.2K, instead of 2.4K.
Terminals 14, 20, 22 - Doesn't show me nothing, instead of 0.
Everything else is perfectly fine.
I doubled checked, I tripled checked and everything is soldered really well and everything goes exactly where it belongs.
P.S - I did the REVISION part where I attach to terminal 14U instead of 22L, and I soldered it at the end of the procedure of building the Crack :
"REVISION 5/6/10:
Making this wire 3” long and
connecting it to Terminal 14U
instead of terminal 22L may
yield more quiet operation."
Please help me enjoying my Crack working as it should be  :)
Title: Re: Resistance (ohms) failure
Post by: fullheadofnothing on July 27, 2015, 09:50:35 AM
This sounds like a bad solder connection or mis-wire somewhere on your ground buss (aka the black wires). The manual says to connect the black lead of your meter to terminal 12. There is a piece of wire that joins 12 and 14, so if you do not have 0Ω between these two points, something is clearly wrong.
Post by: rogerthatmand on July 27, 2015, 07:57:58 PM
Thank you for the comment. I'll check that out.
And what about terminals 6, 10, which gives me 1.4K instead of 2.4K?
(Besides, is it OK that my meter only has a 20K-200K-2000K option and not 10K-100K-1000K option?)
Post by: rogerthatmand on July 28, 2015, 02:57:56 AM
Then I can assume that Terminal 6, 10 are also faulty?
Since I get 1.2K, while at the manual it says 2.4K...(?)
What could be possibly the reason for that?
Post by: rogerthatmand on July 28, 2015, 07:39:25 AM
So the ohms test was OK, then I move over to the volt testing, power on the amp, and after a few seconds the tubes glowed and smoke came out.
I guess there's nothing I can do now and it's total loss?
Post by: fullheadofnothing on July 28, 2015, 08:16:44 AM
What did you do to resolve your resistances?
Smoke is a sign that something is in backwards or otherwise improperly connected. Can you post pictures of your build?
Post by: Doc B. on July 28, 2015, 10:04:14 AM
It's not a total loss, but we need more info to help you sort what happened. Yeah, pictures of the wiring around the power supply in particular would be good, and some of the sockets might help too.
Post by: rogerthatmand on July 28, 2015, 08:40:38 PM
Actually I did nothing to resolve the resistances. It seems that I didn't check it right. Right after I put the negative lead to the 12L, everything was OK.
Except, terminals 6, 10 still gives me 1.2K instead of 2.4K.
In addition, terminal 13 doesn't raise slowly towards 270K, not even close. Barely pass the 1K actually. But since the manual had asterisk sign, I assumed it's OK.
The smoke came out of the transformer, after a few seconds when I power the amp on.
Here are some pictures:
http://imgur.com/a/293t7 (http://imgur.com/a/293t7)
(I created an online album since it crashed twice when I was trying to upload it here)
Post by: Deluk on July 29, 2015, 03:09:01 AM
Black and red shorting on transformer to the left of the 5W resistor on picture #1?
Post by: Strikkflypilot on July 29, 2015, 03:21:51 AM
Any solder on 12L?
Post by: Grainger49 on July 29, 2015, 03:34:09 AM
Any solder on 12L?
I have noticed on a number of terminals the solder is used like chewing gum to stick the leads or wires in place.  It is a good practice to wet the terminal till it flows through the hole.
I suspect you have a number of "cold solder joints" in your build.
But those would not cause smoke.  They would cause no voltage in a number of places.  We haven't found the answer.  Although the transformer wires in the first picture, as Deluk points out, makes it look like those terminals are shorted.  Try measuring resistance from one lug to the other.  It should be low but not under an Ohm.
Post by: Paul Birkeland on July 30, 2015, 12:20:38 PM
Can you add some photos of the relevant parts of the amplifier for this particular issue.  (One of the headphone jack, then another of the terminal strip/octal socket combo)
There is a potential miswire that could cause this issue, and it would be quite tragic if you were to power up the amp under these conditions.
Post by: richmi on July 30, 2015, 04:37:05 PM
The five-colour code for the resistors on the headphone jack should be red, yellow, white, brown, brown for 2.49k ohms.
I looked at the Crack's part list and could not find any resistor with a value of 1.2k ohms. You would have to have two 2.49k ohm resistors in parallel to get half the value.
Perhaps, you created a bridge between the red and white wires at the headphone jack.
Richard
Post by: rogerthatmand on July 31, 2015, 06:02:16 AM
Thank you very much for the response.
I actually didn't understand what you meant by "red black wire shorting" in the first picture. What's exactly is wrong again?
And do you think the soldering isn't good enough? I really tried to bend the wire into the hole so it would stick there, and only after that I soldered it.
And here's another album of the other terminals (plus some headphone jack pictures):
http://imgur.com/a/sBzBA (http://imgur.com/a/sBzBA)
Thank you again! I'd be glad to get additional help to solve my issue.
Post by: Strikkflypilot on July 31, 2015, 06:58:12 AM
Hi!
You have very much solder on several joints, especially obvious on the jack connector.
Some kinds of solder are hard to work with. Do You know what kind You have?
I have learned a great deal from these professional but easy to grasp videos: https://www.youtube.com/playlist?list=PL926EC0F1F93C1837
Also some of Your leads are dangerously long, and should be stripped.
Anyway, I know it is hard to slow down the build, but I am sure You will get the hang of it. It all comes down to practice and quite a bit of patience.
All the best and good luck!
Post by: Paul Birkeland on July 31, 2015, 08:40:48 AM
Here are some things I would work on.
Can you use your DVM to measure the resistance from terminal 3 to terminal 7?  How about terminal 3 to terminal 9?
Post by: 2wo on July 31, 2015, 11:08:27 AM
Also, on the tube socket is the white wire at pin 2 touching pin 1? may be labeled A1,A2, not sure...John
Post by: Rocketman248 on July 31, 2015, 08:53:10 PM
What's the wattage on your soldering iron.  It looks as though your iron is getting just hot enough to melt the solder on the tip, but not hot enough to adequately heat the junction.
Post by: Strikkflypilot on August 01, 2015, 03:08:34 AM
And make sure You have standard issue electronics solder (60/40 tin/lead) with rosin core.
None of that silver crap, damn hard to work with.
I read on a product page it would flow better than standard solder.
Still waiting for that to happen:)
Post by: rogerthatmand on August 04, 2015, 07:49:25 AM
Guys, the frustration is strong with me.
I double checked everything you mentioned. I did fix everything you suspected was wrong (the white wire at the headphone jack seems to touch other wires actually).
But again, I tried to power it on and again - smoke.
The smoke is coming out of the transformer only! nothing else. It seems like the transformer getting over heated.
Any suggestions now?  :(
Post by: Doc B. on August 04, 2015, 08:54:11 AM
Folks this is another of the situations that happens occasionally where a lot of people are showing really good intentions in offering suggestions, but I fear the OP may be getting overwhelmed by all the posts. I would respectfully suggest we let PB work with the OP to sort this one in a methodical fashion.
Roger, don't turn the amp on again until PB posts some guidance. At this point the transformer is probably just fine, but a short somewhere else in the circuit is forcing it to draw way too much current when you turn it on. Eventually that will fry the transformer, and we need to figure out where the short is before running it for any duration. Now that you have resoldered a lot of the connections your best bet might be rechecking all of the resistances and posting any deviations.
Post by: rogerthatmand on August 04, 2015, 11:09:54 PM
I'll check again everything. But can you please explain what do you mean by "PB"?
Post by: Strikkflypilot on August 04, 2015, 11:39:24 PM
PB is Caucasian Blackplate AKA Paul Birkeland.
The one to listen to here.
Good luck BTW!
Post by: rogerthatmand on August 05, 2015, 03:15:22 AM
Oh, ok.. thank you very much.
By the way, about the ohms testing, the black (negative) lead should be placed at 12L all the time? and the red one at the target terminal?
I'm not 100% sure what should i do with the black lead of the meter and I didn't quit understand it from the manual.
Thanks again in advance.
Post by: Strikkflypilot on August 05, 2015, 04:49:03 AM
I know it can be hard to slow down when building this great kit.
The manual is however very clear on this. Page 37 under resistance check tells You to attach the black test lead to ground and preferably terminal 12. Use a clip lead or gator clip so You can concentrate on hitting the right terminals with the red probe.
Post by: Paul Birkeland on August 05, 2015, 09:50:27 AM
Did any of your faulty measurements clear up with some reworking of the amplifier?  Failing resistance checks generally indicates that the amp will blow a fuse when you try to power it up, so there's no need to do that until we clear up the majority of these issues.
I can't quite see for sure in your photos, but it's possible that the 270 Ohm  resistor that crosses over the power transformer may not be connected to the correct terminals.  That in and of itself would be enough to blow fuses endlessly, and that resistor would get nice and toasty in the process.
Post by: Deluk on August 05, 2015, 12:21:32 PM
The pictures of the jack plug certainly seem to show a small solder blob  joining the top two wires, the red and white. PB has circled it on one picture but it's more obvious on one of the other Imgur ones.
Post by: rogerthatmand on August 07, 2015, 12:32:17 AM
Thank you again for the comments! really appreciate it!
I'll go check soon everything you said.
But please - I'd like to know about the testing - How should I really check the ohms with the meter? I'm not sure about the manual explanation.
Should I touch the black negative lead to 12L? I don't really understand the meaning "To the ground of terminal 12". By "ground" it means the plate itself?
It seems that I don't do the checkings right..
And what do you mean by "installing backwards"? Does it matter the direction I put the wire in the terminal?
Looking forward for replies,
Thanks a lot!!
Post by: Grainger49 on August 07, 2015, 12:41:32 AM
Try this sticky:
http://bottlehead.com/smf/index.php?topic=4812.0
I think if you go through this you will either verify your ground or find where you have problems.  It traces it as you should have it wired.
Where I say "Clip your meter lead" I want you to use an alligator clip jumper to connect the black lead and the first ground point.  If you don't have one you need some.  Go to Radio Shack and buy some.  They are cheap and very handy.
Post by: rogerthatmand on August 07, 2015, 03:25:47 AM
Thank you, but I forgot the most important question I had  ;D
How do I check for shorted circuit? I truly believe there's a problem somewhere with shorted circuit at the transformer area.
I don't know what I should do to check it right.
Post by: Paul Birkeland on August 07, 2015, 08:14:06 AM
You perform the resistance checks.
