Resistance (ohms) failure
rogerthatmand · 7434
Offline rogerthatmand
on: July 27, 2015, 08:21:52 AM
Hey guys, I'd like to get some help. I finished building the Crack but I have some issues with the resistance check (the first step, the ohms).
I have a volt-ohm-meter which I configure to 20K Ohms:
Terminal 6, 10 - gives me 1.2K, instead of 2.4K.
Terminals 14, 20, 22 - Doesn't show me nothing, instead of 0.
Everything else is perfectly fine.
I doubled checked, I tripled checked and everything is soldered really well and everything goes exactly where it belongs.
P.S - I did the REVISION part where I attach to terminal 14U instead of 22L, and I soldered it at the end of the procedure of building the Crack :
"REVISION 5/6/10:
Making this wire 3” long and
connecting it to Terminal 14U
instead of terminal 22L may
yield more quiet operation."
Please help me enjoying my Crack working as it should be  :)
Offline fullheadofnothing
Reply #1 on: July 27, 2015, 09:50:35 AM
This sounds like a bad solder connection or mis-wire somewhere on your ground buss (aka the black wires). The manual says to connect the black lead of your meter to terminal 12. There is a piece of wire that joins 12 and 14, so if you do not have 0Ω between these two points, something is clearly wrong.
Reply #2 on: July 27, 2015, 07:57:58 PM
Thank you for the comment. I'll check that out.
And what about terminals 6, 10, which gives me 1.4K instead of 2.4K?
(Besides, is it OK that my meter only has a 20K-200K-2000K option and not 10K-100K-1000K option?)
Reply #3 on: July 28, 2015, 02:57:56 AM
Then I can assume that Terminal 6, 10 are also faulty?
Since I get 1.2K, while at the manual it says 2.4K...(?)
What could be possibly the reason for that?
Reply #4 on: July 28, 2015, 07:39:25 AM
So the ohms test was OK, then I move over to the volt testing, power on the amp, and after a few seconds the tubes glowed and smoke came out.
I guess there's nothing I can do now and it's total loss?
Reply #5 on: July 28, 2015, 08:16:44 AM
What did you do to resolve your resistances?
Smoke is a sign that something is in backwards or otherwise improperly connected. Can you post pictures of your build?
Reply #6 on: July 28, 2015, 10:04:14 AM
It's not a total loss, but we need more info to help you sort what happened. Yeah, pictures of the wiring around the power supply in particular would be good, and some of the sockets might help too.
Reply #7 on: July 28, 2015, 08:40:38 PM
Actually I did nothing to resolve the resistances. It seems that I didn't check it right. Right after I put the negative lead to the 12L, everything was OK.
Except, terminals 6, 10 still gives me 1.2K instead of 2.4K.
In addition, terminal 13 doesn't raise slowly towards 270K, not even close. Barely pass the 1K actually. But since the manual had asterisk sign, I assumed it's OK.
The smoke came out of the transformer, after a few seconds when I power the amp on.
Here are some pictures:
http://imgur.com/a/293t7
(I created an online album since it crashed twice when I was trying to upload it here)
« Last Edit: July 28, 2015, 09:19:22 PM by rogerthatmand »
Offline Deluk
Reply #8 on: July 29, 2015, 03:09:01 AM
Black and red shorting on transformer to the left of the 5W resistor on picture #1?
Offline Strikkflypilot
  • Shellac fiddler
Reply #9 on: July 29, 2015, 03:21:51 AM
Any solder on 12L?
Home system:
DAC: Schiit Gumby
Amp: Bottlehead Mainline
Phones: HD800S
Office:
Sources: Iphone/ Ipod
DAC: Dragonfly Red+Jtrbug
Phones: HD580,HD600 grilles
Reply #10 on: July 29, 2015, 03:34:09 AM
Any solder on 12L?
I have noticed on a number of terminals the solder is used like chewing gum to stick the leads or wires in place.  It is a good practice to wet the terminal till it flows through the hole.
I suspect you have a number of "cold solder joints" in your build.
But those would not cause smoke.  They would cause no voltage in a number of places.  We haven't found the answer.  Although the transformer wires in the first picture, as Deluk points out, makes it look like those terminals are shorted.  Try measuring resistance from one lug to the other.  It should be low but not under an Ohm.
Reply #11 on: July 30, 2015, 12:20:38 PM
Can you add some photos of the relevant parts of the amplifier for this particular issue.  (One of the headphone jack, then another of the terminal strip/octal socket combo)
There is a potential miswire that could cause this issue, and it would be quite tragic if you were to power up the amp under these conditions.
Offline richmi
Reply #12 on: July 30, 2015, 04:37:05 PM
The five-colour code for the resistors on the headphone jack should be red, yellow, white, brown, brown for 2.49k ohms.
I looked at the Crack's part list and could not find any resistor with a value of 1.2k ohms. You would have to have two 2.49k ohm resistors in parallel to get half the value.
Perhaps, you created a bridge between the red and white wires at the headphone jack.
Richard
« Last Edit: July 30, 2015, 04:48:54 PM by richmi »
Richard Milette
Seduction C4S
Extended Foreplay III (converted to 6SN7 Nov. 2011)
Paramount 300Bs
Crack (6SN7) + Speedball + HD650
Reply #13 on: July 31, 2015, 06:02:16 AM
Thank you very much for the response.
I actually didn't understand what you meant by "red black wire shorting" in the first picture. What's exactly is wrong again?
And do you think the soldering isn't good enough? I really tried to bend the wire into the hole so it would stick there, and only after that I soldered it.
And here's another album of the other terminals (plus some headphone jack pictures):
http://imgur.com/a/sBzBA
Thank you again! I'd be glad to get additional help to solve my issue.
  • Shellac fiddler
Reply #14 on: July 31, 2015, 06:58:12 AM
Hi!
You have very much solder on several joints, especially obvious on the jack connector.
Some kinds of solder are hard to work with. Do You know what kind You have?
I have learned a great deal from these professional but easy to grasp videos: https://www.youtube.com/playlist?list=PL926EC0F1F93C1837
Also some of Your leads are dangerously long, and should be stripped.
Anyway, I know it is hard to slow down the build, but I am sure You will get the hang of it. It all comes down to practice and quite a bit of patience.
All the best and good luck!
Home system:
DAC: Schiit Gumby
Phones: HD800S
Office:
