Ok So next attempt
The fuses are 1.5 amp slow blow
I have completely rebuilt the voltage doubler - new caps new diodes , new resistors new tag strip.
Still blowing fuses
Have taken photos during the ( 4th ) rebuild as I add the diodes and the caps . I also rewired the heater supplies just in case .
Without the voltage doubler attached the fuse is fine the secondaries on the transformer read a little high but otherwise as expected . With the doubler in place the fuse blows immediately . it is not attached to the rest of the circuit except the ground wire . I cant see a mistake .
