Eros - Shunt Regulator Voltage Test
onion_breath · 8159
Reply #30 on: July 14, 2017, 07:00:55 AM
Yes, I would go ahead and solder that connection.
Offline onion_breath
Reply #31 on: July 14, 2017, 08:12:36 AM
Okay. Well I soldered the drain wire at center pin on D and also replaced the broken cable and checked all the other cables for cold joints. I also did as Doc B suggested and checked for continuity on the tube socket terminals at D1 and D6. My results are still very low readings  - comparable to my first measurements on D1 and D6. This time around my results were 4.8 VDC on D1 and 3.2 VDC on D6.
Reply #32 on: July 14, 2017, 09:33:16 AM
What voltages do you see at OA and OB now?
Reply #33 on: July 14, 2017, 11:28:30 AM
OA - 3.02 VDC
OB - 4.81 VDC
Reply #34 on: July 15, 2017, 06:28:38 AM
I think at this point that your best bet is to send your Eros in for repair and we can figure out what's going on for you.
