Low Voltage w/Power Transfomer Secondary Test [resolved]
jackhuman65 · 1925
Offline jackhuman65
Hey, I'm getting voltages outside of the specified range.  My secondary tests keep coming up as follows:
7/9: 3.9V (should be 6.5V AC +/-20%)
12/11: 107V (should be 175V AC +/-20)
Is this a problem?  Any tips on how to fix this?
« Last Edit: May 16, 2017, 07:35:01 AM by Caucasian Blackplate »
Reply #1 on: May 13, 2017, 07:15:38 PM
Where do you live?
What voltage did you wire for?
Post pictures.
Offline jackhuman65
Reply #2 on: May 14, 2017, 03:18:31 AM
Maryland, USA
I wired for voltage greater than 115V AC and less than 130V AC
Pictures:
« Last Edit: May 14, 2017, 03:25:02 AM by jackhuman65 »
Reply #3 on: May 14, 2017, 05:11:38 AM
You appear to have followed the wrong set of instructions. Wiring for 120 is on p. 25. It has a red wire that you are missing, and a black wire connecting different terminals. Your wiring matches the 210-225V setup on p. 26.
Offline jackhuman65
Reply #4 on: May 14, 2017, 05:18:59 AM
Wow can't believe I didn't realize that.  Thank you.  This is my first DIY project.
Reply #5 on: May 14, 2017, 05:33:22 AM
Happy to help, that's why the forum is here. Rather than measure success by the dollars made or the reviewer awards won, I measure success by how many people we can encourage to make their own gear and learn in the process. A big part of that is learning that mistakes aren't to be avoided, they are a requirement! You are on your own path to success.
