Can a 5687 work with the crack
tdogzthmn · 5185
Offline tdogzthmn
  • Industrial Designer
on: September 04, 2010, 12:51:57 PM
I found a Tung Sol 5687 which seems to be similar to the 12AU7 but I think the pinout might be different.  Would this tube work in my crack which has the speedball upgrade or would the tube/amp need modification for it to work?
Thanks.
Reply #1 on: September 04, 2010, 04:24:39 PM
I think PB has already said this would work, but the pinout is different andd it would at least need a change of one of the resistors in the C4s, and maybe some other changes to another component or two -- don't recall exactly, but I think it's somwhere in the tube rolling thread.
Offline JC
Reply #2 on: September 04, 2010, 04:31:10 PM
Beside the pinout being different, at a glance it looks to need about 3x the heater current.  You will need to have that available.
« Last Edit: September 04, 2010, 06:26:05 PM by JC »
Jim C.
Reply #3 on: September 04, 2010, 06:57:05 PM
The heater current is available - just barely, but it is there. Trick is, you also need a lot more plate current. I think it's in the archived thread, too late tonight to check though ...  :^)
Offline tdogzthmn
Reply #4 on: September 04, 2010, 09:52:26 PM
Ok, so can anyone see a good reason to make such changes, and what would be a comparable 12AU7 that I could try?
Offline grufti
Reply #5 on: September 05, 2010, 07:13:37 PM
Try the E80CC mentioned in some of the tube rolling threads in the Crack forum.
Reply #6 on: September 10, 2010, 06:11:14 AM
The heater current is indeed barely there to make this work.  The B+ current is also sufficient.  If you have the Speedball upgrade, let me know and I can revisit the resistor changes necessary.
This would very likely be a nice alternate driver tube, and it has a little bit less gain than the AU7 IIRC.  You will, however, want to start with a fresh 9 pin socket to facilitate the modification (complete socket rewiring).
Offline Brillo
Reply #7 on: October 12, 2011, 09:24:37 AM
Paul B.,
I would like to try a 5687 with my new Crack build (with Speedball).  I searching the forum, it's not clear exactly what wiring and component changes are necessary.   Can you (or someone) describe?
Chris
Chris
Reply #8 on: October 27, 2011, 03:42:24 PM
Hello Chris,
Feel free to let me know if you need more info than was contained in my PM.
