Help installing a DACT CT2 in a SEX 2.0
wylymon · 2365
Offline wylymon
on: May 24, 2017, 07:19:18 PM
The DACT did not come with instructions and I have not
found any help on line. The DACT came with an optional
wiring option that allowed solderless connection
by a Molex type connector to the six pins on the DACT.
I can't figure out how to wire the DACT.  Any help would
be really appreciated.
James Wyly
James Wyly
Online Paul Birkeland
Reply #1 on: May 26, 2017, 11:45:23 AM
Set your meter to DC resistance, then turn the volume control all the way down.
There should be two pairs of pins that show almost 0 DC resistance between them.  One pin from each set is ground, the other is signal + out.
Turn the volume control all the way up.  There should now be two different pins that show almost 0 DC resistance between them.  One pin from each set is signal + out, the other pin is signal + in.
Since signal out is present in both sets of measurements, process of elimination will give you ground and signal + in.
