Power on pop/crack
rockdrummer · 1638
Offline rockdrummer
on: May 28, 2017, 05:41:16 AM
Hi everyone. I am running a freshly finished stereomour. It sounds amazing. I use subs and without a separate preamp, I control 2 volumes, one for subs and one for the mains. I built a quickie to control volume for both. I split the signal from the quickie to stereomour and sub amps.
I can't turn on the quickie without a terribly loud popping sound. I have no idea what to do. Isn't the order going on as preamp, then amp? I tried it the other way and the pop still happens when the quickie turns on.
Ben
Reply #1 on: May 28, 2017, 07:25:37 AM
Are your subs off when you turn on the Quickie?
« Last Edit: May 28, 2017, 07:31:23 AM by fullheadofnothing »
Offline rockdrummer
Reply #2 on: May 28, 2017, 09:11:42 AM
They are on an auto setting.
I switched the quickie out. I will get it back in and try that.
Thanks for the idea.
Ben
Offline rockdrummer
Reply #3 on: June 04, 2017, 02:55:07 AM
I feel dumb. I absentmindedly left out those sub amps. On/off is silent now. Thanks.
Ben
