Passive volume control question.
bernieclub · 2959
Offline bernieclub
on: June 04, 2017, 09:35:49 AM
I'm preparing to do some experiments with passive volume on my paramours.   If I can place the amps so that the inputs are very close to each other, and mount a pot within say six inches of the rca jacks, can I eliminate the input resistors all together and let the pot become the input resistor as if it's mounted on the chassis?
Bernie
Bernie Zitomer
Offline bernieclub
Reply #1 on: June 05, 2017, 07:46:47 AM
maybe a better way to ask this...what is a reasonable maximum distance from the pot or input resistor to the tube grid?   Any one have an idea?
Bernie
Bernie Zitomer
Reply #2 on: June 08, 2017, 09:14:04 AM
Hello Bernie,
On the Paramours, there should be a 249K resistor from grid to ground.  If you use a passive volume control with very short cables to the amp, the highest value I could see being sensible would be a 50K control.
If you remove the 249K resistors and plug in your volume pot, you'll now have a situation where if the RCA cable slips out of the amp, the grid of the 12AT7 is now floating, and you risk tube damage.  I wouldn't do this, and having the 249K resistor in there isn't going to load your passive control unreasonably.
There's also the grid stopper, which is a little 220 Ohm resistor between the RCA jack center pin and the grid of the 12AT7, and that also has to stay.
The Stereomour has the passive volume/balance controls acting as a grid leak resistor, but they will stay in the circuit regardless of whether anything is plugged in.
Offline bernieclub
Reply #3 on: June 08, 2017, 09:31:07 AM
Thanks Paul!    Exactly the info. I needed.
Bernie
Bernie Zitomer
