SEX output grounding question
JeffYoung · 1691
Offline JeffYoung
on: September 20, 2017, 09:01:05 AM
The schematic shows both the headphone and speaker outputs being referenced to ground.  However, the TRS socket I got is 3-way switching (and the 0ohm resistors are on the speaker side), so the headphone output is not referenced to ground.
My speaker and headphone outputs are on front and back panels.  I assume it would be OK to make the ground reference at OT1 and OT2 (so that the headphone output is also referenced to ground)?
Jeff.
« Last Edit: September 20, 2017, 11:30:41 AM by JeffYoung »
Reply #1 on: September 20, 2017, 10:19:25 AM
You can do this, or add the ground reference at your headphone jack.
Offline JeffYoung
Reply #2 on: September 20, 2017, 11:30:05 AM
Cool; thanks Paul!
