Buzzing with the power turned off.
StivVid · 2175
Offline StivVid
on: October 02, 2017, 08:06:07 AM
Hi, all.  Just finished my first S.E.X. 3.0 build.  Had a listen last night before the C4S upgrade and everything sounded great.  I heard a short hum through headphones when powering up.  Assumed that was the transformers?  Anyway... as soon as everything warmed up it was nice and quiet and sounded great.  Today, I installed the C4S upgrade and am experiencing an issue.  I hear a constant buzz through headphones when the power is turned off.  As soon as the power is turned on, I hear the hum of the transformers then the tubes warming up, then it's nice and quiet and seems to behave normally.  I'm guessing there's some kind of grounding issue if I hear buzzing before the amp is even turned on.  Any thoughts?
Reply #1 on: October 02, 2017, 08:10:58 AM
How were your voltage checks?
Offline StivVid
Reply #2 on: October 02, 2017, 08:40:10 AM
All checked out.  C4S voltages were 66 at both terminals.
Reply #3 on: October 02, 2017, 09:56:35 AM
I have seen that happen from electro/magnetic fields - it can be from electric fiends (lights, dimmers, etc) or from magnetic fields (nearby transformers, electric heaters, etc.)
Offline StivVid
Reply #4 on: October 02, 2017, 09:58:58 AM
You may be right.  Just checked it again and no buzzing.  Certainly appears to be intermittent.  I'll have to do some trouble-shooting.  Thanks, Paul.
Reply #5 on: October 02, 2017, 03:24:24 PM
No problem. I had that with my first 300B amp - my speakers are efficient (101dB) and I heard a buzzy hum when the amps were off; I even pulled the power cord and input cables, made no difference. As you have found, once the amp is on, it greatly reduces. I have a theory why, but it's too long for a post. :^)
Offline MD1200
Reply #6 on: October 03, 2017, 03:08:17 AM
i get some noise when i have the fluorescent tube lights on in my room from time to time, But i hardly use them anymore since i added a lamp at my desk.
Offline StivVid
Reply #7 on: October 03, 2017, 10:26:05 AM
Well... I haven't heard the buzzing again since my original post. We'll consider the issue solved.for.now. Thanks as always for your help and suggestions.
