installing Beequiet as I buiuld Beepre- voltage tests still still accurate?
kip.duff · 1722
Offline kip.duff
I'm at fork in road where I'm installing volume control wiring in my BeePre.  I would prefer to go straight to BeeQuiet install as part of Beepre assembling.  Will the voltage tests for the stock Beepre in the assembly manual still be accurate?
Dr. Feickert Blackbird II w Reed 2A tonearm and Lyra Skala cartridge.  Eros 2.  Audio Note DAC 2.1 Signature.  BeePre with BeeQuiet and Paramount 1.1 monoblocs into A7 VOTTs or Nagoaka folded horns.
I would suggest that, if you are unsure of whether the testing of the circuit is valid with the shortcut being installed during the initial build it probably makes sense to build the amp stock, make sure it passes all the tests and then install the upgrade.
Offline kip.duff
OK.  THanks for advice.
