wiggly 300b socket
aroide · 2301
Offline aroide
on: January 12, 2018, 02:49:17 AM
I built my BeePre several years ago and LOVE the sound and listening experience.    I had a bad 300b socket originally that wouldn't tighten, got a replacement which tightens, but the ceramic part wiggles a bit in the metal casing.  That didn't bother me for years.
I switched from my grey bottle PSvane tubes to Sophia Princess Carbon.  I noticed that the tube in the wiggly socket really rings with microphonics.  The old tubes still ring in that socket, but less than the carbons.  Switching tubes, its the socket not the tube.  The tube can rock back and forth freely as the ceramic moves in the metal clamp.  The tubes are solidly plugged into the ceramic, but the whole ceramic wiggles. I need to make that socket rock solid as the ringing is driving me crazy.
I would rather not replace that socket yet again (Its a pain to do).  I was thinking of getting some high temp silicone and injecting it between the metal and ceramic to stop the wiggles, and likely dampen any vibrations transmitted.  What are your thoughts on this?  Anyone else needed to do this with wiggly sockets?
Wiggly Sockets.. sounds like a British kids band.
Mac mini running Roon->
Mytek Brooklyn DAC+->
Darwin Truth RCA IC->
BeePre (BeeQuiet,  Mundorf Ag/Au/Oil, Sophia Royal Princess 300B)->
Audioquest Colorado->
Rogue Audio Atlas Magnum amp (Psvane small signal tubes, KT150s)->
Audioquest Gibraltar-speaker cables>
Magnepan 1.7 & REL T-5
Reply #1 on: January 12, 2018, 03:54:06 AM
Super glue will actually take the heat down there and eliminate the wiggle.  It's also what I use when a tube is loose in its base.
Offline aroide
Reply #2 on: January 13, 2018, 05:11:07 AM
Even easier to inject.  superglue it is.  thanks  :)
Offline Thijs
Reply #3 on: February 07, 2018, 01:18:41 AM
I was having a similar issue and thankfully found this post. I tried the super glue and it worked like a charm! Thanks.
Offline bombay317
Reply #4 on: February 19, 2018, 05:20:55 AM
Both of my BeePre sockets are wiggly and I will be trying this method to fix it.  Incidentally, I assembled the Kaiju around the same time and it doesn't have the wiggly issue.  The Kaiju is a thicker plate, perhaps that is part of the issue here?
Niagara 7000
Benchmark DAC3L (XBOX1 and TV)
CA Performance w/ Satisfy Turntable
Talismann V2 CA Cartridge
Tavish Designs Adagio Vacuum Tube Phono
BHSE Amp
Stax SR-009
BeePre 300B w/ BeeQuiet and Cinemag Transformers
Kaiju 300B w/ DC Filament
Jäger Speakers
Transparent and Benchmark Cables
Offline bombay317
Reply #5 on: March 05, 2018, 05:47:01 AM
I also used an epoxy to freeze these in place.  I used 3M EC2216 because I had it handy.  It worked like a charm.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
