Loud Humming goes away when i tap the tube
Smienov · 1513
Offline Smienov
on: January 12, 2018, 04:37:34 PM
Hi guys.
I have a crack i built in 2014, this has always been a problem but now decided i want to sort it out.
The amp works great but intermittently a loud hum will start, and i found if i just tap the tube with my fingers, it goes away, it may comeback in seconds, or it could be minutes.
Does this mean the tube is a dud or its a cold solder joint perhaps? Thank you.
Reply #1 on: January 13, 2018, 04:18:32 AM
This is almost certainly a cold or unsoldered joint in the amp.
