Partial Speedball Upgrade: Voltage Good, 1 led not lighting up
CrackNoob · 1998
Offline CrackNoob
Hello Guys,
I just finished first part of the speedball upgrade, all the voltages were in the correct range per instruction manual. One LED, the upper right side, D1 I believe, it's not lighting up. I went ahead and listen to my Crack W/ Partial upgrade, and it seems to be working fine. Am I in the clear?
« Last Edit: January 18, 2018, 06:26:18 PM by CrackNoob »
Reply #1 on: January 18, 2018, 07:03:43 PM
Can you post your voltages?
I would look for a solder joint on the bottom side of the board that's touching a neighboring joint by mistake.
Offline CrackNoob
Reply #2 on: January 19, 2018, 03:29:16 PM
I found out what was wrong, I had one of the PN2907A facing the wrong way. Now, the hard part, trying to get it out...... I been using my crack, do you think it's safe for the time being?
Reply #3 on: January 22, 2018, 06:27:12 AM
I wouldn't use the Crack with the transistor in backwards.
Offline CrackNoob
Reply #4 on: January 23, 2018, 09:50:50 AM
Thanks, I got it fixed. I installed the second portion of the Speedball, and Voltages are the following:
OA 109
OB 109
G 0
B+ 185
« Last Edit: January 23, 2018, 10:34:41 AM by CrackNoob »
Reply #5 on: January 24, 2018, 04:14:16 AM
Those are normal voltages for the larger board.
