General Category
General Discussion
Bad 2a3? And loose 4-pin sockets...
Sugar Man
2149
Sugar Man
Full Member
January 21, 2018, 05:31:46 AM
So I just had one channel of my Stereomour II lose about 80% of its volume. Switched the 2a3's (JJ's) and the problem moved to the opposite channel. Put my Sovtek's back in and everything is back to normal. Assuming this is just a bad tube. Prior to this, I've noticed that the 4-pin tube sockets are not tight. Is it possible to manually tighten those? I believe I saw a post or two on this somewhere, but couldn't find it again after a search.
Mike "Stein" Ayotte
Current Gear:
Herron Audio VTPH-2a
Rega RP8 w/ Apheta 2
Bluesound Node 2i
Stereomour II w/ Jupiters
Eros w/ Mundorf Silver Oils
Blumenstein Orcas & Subs
borism
Full Member
Re: Bad 2a3? And loose 4-pin sockets...
Reply #1 on:
January 21, 2018, 10:11:56 AM
The same loss of volume on one side happened to me with two different pairs of JJ 2A3-40s. As in your case it followed the tube when switching sides. This makes lose sockets a less likely cause. In my case it was a tube failing both times.
Fortunately, my tubes were still under warranty and replaced for free. Ultimately, I switched to Emission Labs solid plate 2A3s and haven't had any problems for more than 2 years.
Boris
Sugar Man
Full Member
Reply #2 on:
January 24, 2018, 05:35:40 AM
Still lust for the EML's true meshies, soundwise and visually. My concern with the loose sockets is that the Eurotube site mentions loose sockets causing tube failure.
Mike "Stein" Ayotte
Current Gear:
Bluesound Node 2i
Rocketman248
Full Member
Reply #3 on:
January 24, 2018, 03:05:20 PM
I too had the same problem with the JJ 2A3-40s. Never buying them again.
Nick DeBrita
Yokosuka, Japan
Paul Birkeland
Global Moderator
Hero Member
Reply #4 on:
January 24, 2018, 06:29:37 PM
When you mention a loose socket, is it failing to make contact with the tube?
The current 4 pin sockets that we use are a bit flexible, which makes them more gentle on the tubes when inserted, but contact quality is quite good.
Sugar Man
Full Member
Reply #5 on:
January 25, 2018, 07:49:13 AM
Yes, PB, the 2a3's are loose in the 4-pin holes. Occasionally will have a channel go out and I will adjust the offending tube and sound returns. Can I use a jeweler's screwdriver to adjust them from the top?
Mike "Stein" Ayotte
Current Gear:
Bluesound Node 2i
Paul Birkeland
Global Moderator
Hero Member
Reply #6 on:
January 25, 2018, 07:50:30 AM
You can squeeze them together a little from the bottom (emphasis on a little).
Sugar Man
Full Member
Reply #7 on:
January 25, 2018, 07:52:12 AM
Thanks, I'll give that a try - carefully.
Mike "Stein" Ayotte
Current Gear:
Bluesound Node 2i
General Category
General Discussion
