Heavy Distortion
bmnathe · 4097
Offline bmnathe
on: January 26, 2018, 01:57:41 AM
Hey guys - I bought my kit assembled from the first owner.  It worked great for a couple of months until recently - it started producing heavy distortion at any volume level; seems to be mainly from the lower frequencies.  I don't have much issue until a track with bass is played.
When I first received the kit, I noticed that two wires were misplaced (reversed) on the balanced jack.  I fixed that and no issues.  Since the distortion started, I re-soldered nearly every joint and biased the tubes a few times (not much drift).  Besides verifying correct wiring, soldering, etc. on the actual amp - I have tried different sources, power plug, power supply, wiring.
The tubes glow like normal.  I noticed that one power tube is a bit microphonic when I touch it.  This tube seems to produce the most distortion (checked by swapping channels) although both channels are distorted.
Anything else I should check before I buy new tubes?
thanks,
B
Online Paul Birkeland
Reply #1 on: January 26, 2018, 03:49:07 AM
Have you checked all the voltages?
Offline bmnathe
Reply #2 on: January 26, 2018, 12:57:46 PM
Yes - I check all voltages and resistances - everything checks out.  There's no obvious signs of capacitor damage - no leaking or bulging.  All ground wires and nodes are grounded.
Reply #3 on: January 26, 2018, 01:16:57 PM
Have you changed anything upstream or downstream of the amp, like headphones or source?
Offline bmnathe
Reply #4 on: January 27, 2018, 03:37:29 AM
No - all sources, cables, power source, etc. is the same as when the mainline was working well.
Reply #5 on: January 27, 2018, 04:46:29 AM
My best guess is that you have a flaky solder joint that's common to both channels.  I've had issues like this pop up on Cracks when there's a bad solder joint somewhere on the shared ground buss.
Offline bmnathe
Reply #6 on: January 27, 2018, 04:49:00 AM
thanks - I'll double check it but I re-soldered everything already..
Offline bmnathe
Reply #7 on: January 30, 2018, 07:37:28 AM
Guys - I did nothing else and the issue has 'magically' resolved itself.  Not sure what the issue ever was.....I didn't even touch the unit.  I don't think it's a power supply issue because I run through a voltage regulator.  I am still going to install new tubes because one power tube is a bit microphonic....
thanks!
B
