Right Channel - intermittent low noise
HotBot · 1768
Offline HotBot
on: January 26, 2018, 11:05:04 PM
Hi all
I build the crack without issue. I did not notice anything special except on the volume potentiometer crackling noise (almost completely gone after few manipulations and adding a contact cleaner). Then after +/- 8hours of pleasure I added the speedball.
Now my problem is only on the right chanel. I have a non-permanent noise. He's coming, he's going. very disturbing at low volume.
-Some times when I unplug/plug my headphone the noise goes away.
-Some times when I power off/on the crack the noise goes away.
I have no experience in electronic, this is only my third eletronic build.
Maybe a ground or capacitor issue  ???
Thank's for you'r help (and sorry for my poor english).
PS: Of course, as if by magic. No issue at all this morning  :o
I send this post anyway if you have an idea of what to check when I hear the noise…
Setup: Linux kernel 4.11.12-1-RT16-Manjaro > DeaDBeeF > (USB) > ADI-2 Pro > (Neutrik Jack/RCA "Profi" + SC-ALBEDO MKII) > Crack > Beyerdynamic T90
« Last Edit: January 27, 2018, 05:18:04 AM by HotBot »
Reply #1 on: January 27, 2018, 04:53:49 AM
I would resolder all of the joints in the original build.  Sometimes when installing a Speedball, you'll disturb a joint that was working properly previously, but wasn't quite all the way solid.
Offline HotBot
Reply #2 on: January 27, 2018, 05:32:04 AM
I agree  :-[ I noticed today when I move the Crack (or unplug the jack and move the front panel just a little) with the vibrations the noise goes away.
I was quite proud of my welds. I will look on this.
thx  ;)
« Last Edit: January 27, 2018, 05:35:19 AM by HotBot »
