On Sale!
adydula · 13023
Offline adydula
Reply #15 on: February 12, 2018, 02:59:03 AM
Where did you get the two adapters?  I am not afrdi to cut vs $150 for another cable...ok with the solderig etc...
and thanks for this info!
Alex
Reply #16 on: February 12, 2018, 04:30:56 AM
Reply #17 on: February 12, 2018, 04:37:58 AM
I doubt there is any real advantage to adapting a common cold leg for right and left type of TRS cable to a 4 pin XLR. The idea behind the 4 pin XLR is that you can use separate hot and cold legs for each channel, i.e., a four wire cable all the way back to the drivers.
Reply #18 on: February 12, 2018, 05:05:46 AM
The HD800 cable is a four wire cable with the two cold legs joined at the TRS plug. Cant speak for the T1's as i never owned them.
« Last Edit: February 12, 2018, 05:08:12 AM by mcandmar »
Reply #19 on: February 12, 2018, 05:17:21 AM
Cool, so in that case replacing the TRS plug with a 4 pin XLR plug will indeed change the cable to separate cold legs. But making an adapter with an inline TRS jack and 4 pin XLR plug will not change anything.
Reply #20 on: February 12, 2018, 05:47:53 AM
It means you can plug said headphones into a Crack :)
Reply #21 on: February 12, 2018, 06:38:20 AM
TRS jack, 4 pin plug will not plug in to Crack. The opposite gender adapter would.
Reply #22 on: February 12, 2018, 06:50:46 AM
I think your getting confused here, the connector in the middle of the cable is a male/female 4 pin XLR mated together.  Its essentially only a straight through connector.  Take the end off you have a male four pin XLR. Put it back on you have a regular TRS Plug.
Offline ALL212
Reply #23 on: February 12, 2018, 07:05:17 AM
I had my HD800s repaired by Sennheiser (the little "clicky" ball fell out of the headband)  I kept all accessories as requested.
I got a free OEM TRS cable in return.  I'd be willing to play "let's make a deal" on it...
Aaron Luebke
Reply #24 on: February 12, 2018, 08:34:14 AM
Yes, sorry, I did not see that the cable was modded to XLR before the adapter was made for it.
Offline Sp33ls
Reply #25 on: February 20, 2018, 07:06:00 AM
Aww, man. I missed the sale :(
I wonder how long it'll be until the Mainline goes on sale again...
Offline NightFlight
Reply #26 on: March 07, 2018, 04:23:05 PM
Its what... $200? The mainline is worth it either way.  The Mainline doesn't roll tubes (much) so you'll save a lot more not going through that in the elusive tube search.  If it goes on sale, it's just stars aligning really.
OTOH, $200 keeps companies like BH alive. I have no qualms separating my cash to these folk. Honestly, I can't think of money better spent.
Well, maybe feeding starving orphans...  :P  Maybe.
Offline Adrian
Reply #27 on: March 13, 2018, 01:17:06 AM
It's been five weeks since my order on 2/6/18 and I check everyday for a shipping notice.
I'm anxious and excited to get started on this new amp.
Adrian C.
Offline jjvornov
Reply #28 on: March 13, 2018, 03:45:23 AM
Part of the fun is clearing out the bench space, looking at the manual, clearing out a space where it's go when done. Quite a different experience from ordering same day from Amazon!
James
Offline adydula
Reply #29 on: March 13, 2018, 02:19:44 PM
Yahoo!!
Just got the ship email!
Will be here next week, Tuesday the 20th....
Soldering Iron is warming up!!
lol
Alex
