On Sale!
adydula · 13022
Offline adydula
Reply #30 on: March 20, 2018, 03:15:22 PM
I got the kit today and took inventory and started the mechanical part....am short one of those #6 fiber shoulder washers that are used to mount the smaller transformers to the mounting plate and 2 49.9 ohm resistors, got 49k instead.... :>)
no biggie, sent a note to the parts email and got a fast reply from Josh! Thanks for the fast reply...I am continuing on the build and when the washer and resistors arrive it will be a simple install....
Going to paint the main power xfmr top housing a gloss black and tung oil the base. I found some clear Gorilla glue for wood etc that worked well for gluing the sides together.
Cant wait to hear how this amp compares to my Crack!
Alex
Reply #31 on: March 21, 2018, 04:19:06 AM
Could you post a photo of the 49K resistors?  49K is not a value we stock, but once every 5 to 10 years, the wrong resistor gets ordered or the supplier packs the wrong resistor, so it would be good to see what you have on hand.
Offline adydula
Reply #32 on: March 21, 2018, 05:22:19 AM
Here ya go....
Reply #33 on: March 21, 2018, 05:23:04 AM
Josh is aware of the issue. We did get the wrong value and the correct one is on the way.
Offline adydula
Reply #34 on: March 21, 2018, 05:24:25 AM
Just saw Doc's post....I also need one of those small #6 fiber shoulder washers to complete the mounting of the second OT3 smaller xfmr...
Alex
Offline jjvornov
Reply #35 on: July 06, 2018, 06:39:31 AM
So it took me 3 months to get around to building the Mainline. All checked out and worked beautifully first time firing it up!
Of course there were a few miswires along the way, but I caught them by carefully checking over the circuit at each step.
So far the sonic quality is as advertised- quite neutral and extended with absolutely silent background and huge amounts of detail. Great for listening deep into the mix on complex pieces of music.
Offline adydula
Reply #36 on: July 31, 2018, 04:52:43 AM
Congrats on your build. It is really a very nice amp....and builing it yourself is a great experience!
Enjoy!
Alex
Offline Detailer
Reply #37 on: July 31, 2018, 07:21:54 AM
Well done, I hope mine goes as smoothly, ordered yesterday :) (this is my first post here!)
Reports like yours made it easier to pull the trigger.
Offline adydula
Reply #38 on: July 31, 2018, 11:03:09 AM
Just take your time, really pay attention to where what parts need to go on the circuit boards.....check once, check twice!
Good Luck!
Alex
Offline Detailer
Reply #39 on: August 02, 2018, 02:16:45 PM
Doc, can the wooden body be supplied in yellowish oak?
If so how much $ pain will it cause me.
Reply #40 on: August 02, 2018, 06:14:53 PM
We supply the kits with alder bases as shown on our web site. Talk to John Rutter at Harmonic Design Works for a custom base from other material. He mills the bases we use.
http://www.harmonicdesignworks.com
Or just by some oak colored stain.
Offline Detailer
Reply #41 on: August 03, 2018, 01:22:12 AM
Great, thank you.
