Kaiju without input potemtiometers
fritzthecat · 3320
Offline fritzthecat
  • Analog Chris - Fritzthecat
    • Lakeside Audio Association
on: February 16, 2018, 02:51:07 PM
Hi there
just finished teo Kaijus and using them for quite a while in my active speaker setup - never ever used the input potentiometers to adjust volume - just about to finish my third one and would like to do it without using the input potentiometers if possible.
Did anyone remove or bypass these pots?
How to wire without the potentiometers? Anything I should be aware off?
It would be great to get some guideance and advice how to build the Kaiju without input potemtiometers.
I would like to use these huge RIKE AUDIO 10uF S-Cap 2 types - I am very curious to hear my third Kaiju using those huge caps...😜
Looking forward to read from my fellow Bottleheads...🤗
Thamk you & all the best wishes from Switzerland, Chris
Chris
Sony 557ESD
Thorens TD 124 Mkll
Lenco L70 (PTP tuned)
Apple Mac Pro / Media Center 23
AN Kits L4 Preamp
AN Kits L4 DAC / MiniDSP
AN Kits L3 Phono / Bottlehead EROS
Bottlehead Kaijus for JBL 2402, JABO 75 (JBL 2445/Truextent), Orishorn 150 (JBL 2108)
Silvercore 833C for (Klipschorn/Crites)
Reply #1 on: February 17, 2018, 07:04:52 AM
Hello Chris,
You'll need a pair of 100K resistors if you want to leave the pots off.  You can install them across the RCA jacks.
Offline Sp33ls
Reply #2 on: April 12, 2018, 07:18:01 PM
Hi Chris,
I was curious as to what sonic differences you've noticed between your (mostly) stock Kaiju and your fully modded Kaiju. What's your experience been?
Offline richp4003
Reply #3 on: June 13, 2018, 07:29:18 AM
Hi there
Chris,
Just saw your profile and saw you have the rather elusive Silvercore 833s.. How does this amp compare to the Kaiju? Always been intrigued by the 833 but it also seems to bring its fair share of headaches along for the ride (give its high voltages)
