Re: SpeedBall voltage reading not as expected. [Resolved]
shrapnel · 1657
Offline shrapnel
Hi, my voltages for the bigger board are not as expected for terminal OA. Here are the voltages:
OA = 153 V
OB = 117 V
B+ = 203 V
G   =  0.03mV
Also the LED in position D2 on side A does not glow. A side transistor with heat sink is cold to touch. B side is warm to touch. Please help!
S
« Last Edit: March 02, 2018, 07:37:08 AM by shrapnel »
Reply #1 on: March 01, 2018, 06:35:53 AM
This can be typical for a bridged or missed solder joint on the large PC board.
Are the voltages OK on the small board up front?
Offline shrapnel
Reply #2 on: March 02, 2018, 07:36:41 AM
Thank you, I reflowed the connections from the lower lug plates to the big board and it came to life. I must say, I was blown away by the change in sound. It added so much depth to the music. I lived with the standard crack for 1 year before I put in the speedball. It was like hitting the powerband on the Motorcycle at 6k rpm. Fabulous!
