resistance check - terminal 9
Guest · 6224
kvh
on: September 25, 2010, 05:42:26 AM
probably foolish question.. resistance reading at 6 9 (nine) is not fluctuation, just showing around 1.6R.. voltage readings seem ok.. i don't have a turntable setup at the moment, just going through this and checking it again after it's been unused for a while.
thanks,
mk
« Last Edit: September 25, 2010, 06:50:00 AM by kvh »
Reply #1 on: September 25, 2010, 06:10:28 AM
T6 is the top, +, of the heater supply.  If the reading is steady the capacitor is charged.
Are you reading 1.6 ohms to ground?  You should have a high reading to ground unless the tubes are in.  The resistance readings are with the tubes removed.
kvh
Reply #2 on: September 25, 2010, 06:50:41 AM
hi,
my brain isn't working today.. i mean terminal 9, not 6. thank you for the speedy response. :)
Reply #3 on: September 25, 2010, 09:50:01 AM
T9 and T6 are virtually the same spot.  What I said applies.
kvh
Reply #4 on: September 26, 2010, 04:26:57 AM
Thanks... I was getting weird readings w/ my meter... replaced batteries and everything checked out ok.
appreciate the help,
matt
Reply #5 on: September 26, 2010, 04:45:32 AM
Time for tunes now!
