pre out inputs source inputs just received a pre built pre amp
sharethemusic · 2091
Offline sharethemusic
hi,i just received a built 300b pre amp....which is the pre out to go to my amplifier.?..the rca unbalanced closest to the balanced  or..the other end..i have no manual    also,what are the "coarse" and fine" adjustments and where should i intitally set them    regards andy
Offline Chris65
You have posted this question twice. Here is my answer in your other thread:
If you mean the BeePre 300B Pre-Amp, then the output is from the two sets of jacks at the back right - XLR's and RCA jacks in the standard configuration. The three sets of RCA jacks inboard are the inputs.
So, left to right: Input 3, Input 2, Input 1, Output 1 (RCA) Output 2 (XLR)
The Coarse & Fine are the Attenuator (volume control) adjustments. Initially set them to 0! Then set the Coarse control to the general listening level you want, then use the Fine control to adjust the level to exactly where you want.
