Replacing 9 pin tube socket with 8 pin octal socket
TravAndAlex · 3233
Offline TravAndAlex
on: March 16, 2018, 02:07:20 PM
I'm doing a major Crack rebuild and since I have far more 6SN7 tubes (currently with the Garage1217 adapter), I'd like to just enlarge the 9 pin hole and replace it with an 8 pin octal socket that I have on hand.  Is there a guide or listing of what pin numbers will change from the 9 pin to the 8 pin?  Searches have found others that have done this, but not the specifics.
Also, can you run a 6SN7 without the Speedball upgrade?
Cheers!
Offline Natural Sound
Reply #1 on: March 17, 2018, 10:52:52 AM
What I did was print out the datasheets for the 12AU7 and 6SN7 and put them side by side. Then make the necessary pin number changes.
http://tdsl.duncanamps.com/show.php?des=12au7
http://tdsl.duncanamps.com/show.php?des=6sn7
The only other thing you need to consider is where the LED's tie to the Center pin of the 9 pin socket. The 8 pin doesn't have a solder tab like the 9 pin does. I added a small terminal strip near the Octal socket. There was a photo I posted a while back but I think it was on the other (old) forum.
Yes, the 6SN7 will work just fine with or without the Speedball upgrade.
Offline TravAndAlex
Reply #2 on: March 17, 2018, 01:12:20 PM
So just to confirm that I'm not too stunned about the whole thing... I'm basically matching pin layout in the diagram?
9-pin   8-pin
1   2
2   1
3   3
4   7
5   8
6   5
7   4
8   6
9   -
« Last Edit: March 17, 2018, 01:26:20 PM by TravAndAlex »
Offline diynewbie
Reply #3 on: March 18, 2018, 03:09:00 AM
I'm probably wrong, but I don't think that is correct.  It looks to me like you do not have a completed circuit for the heater.  I think 9 should go to 8 and 4/5 should go to 7 (or vice versa?).
Reply #4 on: March 18, 2018, 10:07:59 AM
Good catch. You are correct.
Since the Crack uses AC heating the polarity isn't important.
9-pin   8-pin
1       2
2       1
3       3
4/5    7
9       8
6       5
7       4
8       6
Offline InnerTube
Reply #5 on: March 18, 2018, 10:36:19 AM
Can I use an adapter to run the 6sn tube?  If so, do you know if there is such an adapter available?
Innertube (John Spain)
[email protected]
Offline Chris65
Reply #6 on: March 18, 2018, 11:43:10 AM
Yes. Available from various sources, including that famous auction site.
Offline InnerTube
Reply #7 on: March 18, 2018, 02:41:36 PM
Thanks very much for your reply.  It will be quite helpful to me.  I have several 6sn tubes that I used in a Darkvoice 336 before the Bottlehead.  I will get an adapter right away.  Thanks again
[email protected]
Offline borism
Reply #8 on: March 18, 2018, 02:47:37 PM
You should also look at this thread:
https://bottlehead.com/smf/index.php?topic=7742.0
Not all adapters are equally good. I got one of these and have had no issues.
Boris
Offline Chris65
Reply #9 on: March 18, 2018, 02:56:40 PM
Never had any issues with any of the adapters I use :D. Possibly the nicest are the Teflon ones:
https://www.head-fi.org/threads/new-product-universal-teflon-tube-adapter.548267/
Offline Kitchener
    • I made something!
Reply #10 on: March 19, 2018, 12:38:12 AM
That forum thread is pretty dated by now, their website has them under Accessories.
Also, starting at $40 they seem to have a healthy percentage of audiophile tax applied!  ;D
« Last Edit: March 19, 2018, 01:09:59 AM by Kitchener »
Modded, Speedballed Crack + Sennheiser HD6XX
STAX SRM-353X + SR-L500
STAX SRM-313 + SR-L300
-Jørgen E. J.
Offline TravAndAlex
Reply #11 on: March 20, 2018, 06:22:51 AM
Thanks for the help guys!
