Kaiju Right Channel Out
bombay317 · 7702
Offline bombay317
on: March 18, 2018, 04:50:47 PM
My right Kaiju channel started getting quiet, and now it wont even make noise.  I flipped it over and D1 and D2 on the B side are not lighting up on the right channel.
Voltage Checks Right:
IA=517.5V
OA=357V <--looks bad
IB=364.4V <--looks bad
OB=-0.039V <--looks bad
Voltage Checks Left:
IA=516.0V
OA=297.0V
IB=297V
OB=162.5V
Are Q1 and 2 out? i was hooked into the ground of input AC.  Should i try reflowing the C4S board?
Niagara 7000
Benchmark DAC3L (XBOX1 and TV)
CA Performance w/ Satisfy Turntable
Talismann V2 CA Cartridge
Tavish Designs Adagio Vacuum Tube Phono
BHSE Amp
Stax SR-009
BeePre 300B w/ BeeQuiet and Cinemag Transformers
Kaiju 300B w/ DC Filament
Jäger Speakers
Transparent and Benchmark Cables
Offline bombay317
Reply #1 on: March 20, 2018, 05:32:36 AM
I did some reflowing of the board and havent gotten the right channel to come up, it was a cursory effort and I will try more in depth work tomorrow.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #2 on: March 20, 2018, 06:59:47 AM
These are wired together and can't be different.
Yes, this is bad.
What's the Kreg voltage on the B side?
Offline bombay317
Reply #3 on: March 21, 2018, 04:02:24 AM
Right Channel
KregA: 30.1mV
KregB: 14.9V
Left Channel
KregA: 3.5V
KregB: 7.2V
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #4 on: March 21, 2018, 04:10:29 AM
Swap the 5670 tubes to be sure the issue doesn't follow a tube.
I would suspect an issue with the string of black zener diodes that snake around on the terminal strip under the PC board.  Sometimes long uncut leads can create shorts.
Offline bombay317
Reply #5 on: March 21, 2018, 05:20:04 AM
I did do the swap and it did not follow the tubes when it was at my house.  I can do it again in the lab to make sure.
I will inspect the zeners.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Offline bombay317
Reply #6 on: April 09, 2018, 11:52:24 AM
I inspected the zeners and they appear to all be clear.  I also checked them with the voltmeter and they are all good.
I also reflowed everything and am still getting the weird performance.  I am thinking that I should check the other components on the board and potentially replace some of the fets and stuff.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #7 on: April 11, 2018, 08:11:42 AM
Did you reflow the joints on the PC board?
How are the OA and OB voltages on the offending board?
Offline bombay317
Reply #8 on: April 12, 2018, 04:51:02 AM
OA: ~364V
OB: -0.087V
reference connected to -reg. some other voltages:
Q1C (B): 350V
Q1B (B): 364V
Q2B (B): 364V
breg (B): 364V
Kreg (B): 15V
Kreg (A): 30mV
Of note, D1 (A) and D2 (A) are lit, D1 (B) and D2 (B) are not lit, and they shouldnt be based upon the voltages.  they are not conducting for some reason.  I guess also Rdb and or Cdelay could be shorted, i can measure them too.  It does seem like Q1/2(B) are not conducting.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #9 on: April 13, 2018, 07:20:46 AM
We have some odd circumstances here.  KregB has 15V, which is plenty to juice up the HV regulator and get your OA voltage down where it's supposed to be, but that's not happening.
If we look at the 5670 plate curves, 15V on the cathode and 364V on the plate means that no current is flowing.  My suggestion would be to remove the wire going into IB, then recheck the voltages.
I strongly suspect a soldering issue on that PC board is causing the issue, with some emphasis on the center legs of each MJE5731A.  The other option is that there's a shielded twisted pair of wires that connect to pins 1 and 9 on each 9 pin socket.  If that has come loose on the offending side, you'd end up with voltages like these.  You'd also end up with a 5670 that doesn't glow visibly.
Offline bombay317
Reply #10 on: April 25, 2018, 04:55:55 AM
I will take a look at these suggestions in the next couple of days.
The way that this started was gradually decreasing output on that channel.  It was working fine, then i noticed that i would have to keep increasing the output of that channel.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Offline bombay317
Reply #11 on: June 09, 2018, 03:47:37 AM
I haven't had the time to look at this so I am sending it in for the repair service!
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Offline bombay317
Reply #12 on: August 14, 2018, 03:40:32 AM
Interesting update.  I did send this for repair and got it back and everything is working (the repair service is pretty great if you get strapped for time).  However, i just did the BeeQuiet upgrade, and then the right channel appeared to be out again.
Some thoughts / things I did:
1. The BeeQuiet upgrade removes the balance pot, so there is a good chance that I had been attenuating the right channel a lot on the original BeePre I had set up.
2. After doing the upgrade, I switched the output L/R channels, and the "quiet" side stayed on the right channel, indicating that this issue is with the Kaiju not with the BeePre with BeeQuiet upgrade
3. I rotated the 100k balance pot on the Kaiju one full rotation, and then everything appears to be back to normal balance.
4. if the levels drift again, such as the volume continuing to drop on the right channel, something would be off and need more troubleshooting.
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
Reply #13 on: August 14, 2018, 05:32:25 AM
Check your cables.  This could be a bad cable.
These are not balance pots, they are trim pots for minor level differences.
What happens if you change the interconnect cables at the Kaiju?
Offline bombay317
Reply #14 on: August 14, 2018, 03:43:02 PM
I changed the RCA cables going into the input of the Kaiju, and it still gives what would seem to be normal balance and power sent to both speakers.
Could there have been an error in my assembly of the BeePre in the first place that was fixed with the changing over to the BeeQuiet?
Niagara 7000
BHSE Amp
Stax SR-009
Jäger Speakers
