BeePre Output transformer advice
brightcity · 2115
Offline brightcity
on: March 21, 2018, 07:50:51 AM
Hello, I was wondering if anyone has used or recommends a output transformer for the BeePre?
I recently added 10K:10K transformers to the output of my DAC after the output cap and it did wonders for the sound.
Reply #1 on: March 21, 2018, 08:04:31 AM
What would you like to accomplish by adding a transformer?  (a big part of why the BeePre sounds the way it does is the lack of output transformers)
Offline brightcity
Reply #2 on: March 21, 2018, 08:59:32 AM
No reason other than it benefited my DAC. True, it will probably change the way it sounds.
Reply #3 on: March 21, 2018, 09:05:47 AM
Generally, a 1:1 transformer at the output of a component is pretty uncommon.  It's more common to see some step-down, which can help with driving long cables.
What is the output impedance of your DAC?
It's completely reasonable to add 10K:10K input transformers to the BeePre.  We left holes on the chassis that will accommodate several different transformers.
