tube pop/flash on powerup
calbruc · 1829
Offline calbruc
on: April 19, 2018, 07:16:05 AM
Hey guys,
I just finished building my Crack three days ago. To my astonishment, it passed the resistance and voltage checks and has been working like a champ. Put quite a few hours on it in the past few days.
Today when I turned it on, the 6080 tube popped with a visible flash. I shut it off and tried it a little later, tubes warmed up and it seems to be working fine.
I searched the forum and only found a couple results about this. One said that it could have been some gas in the tube burning off and not likely a big deal, another seemed to think circuit checks were in order.
I was just wondering if anybody had any ideas about this or things I should look for when troubleshooting.
Offline Laudanum
Reply #1 on: April 19, 2018, 07:27:10 AM
Could be as simple as the tube going south.  I had a 5998 tube do as you describe 3 or 4 times before taking a dirt nap.   It may not be the tube but it's a good idea to have a spare or two on hand.   Having a spare to swap in would easily rule the tube in or out as being the culprit.   The 6080's and 6AS7's are still inexpensive.
Desmond G.
Reply #2 on: April 19, 2018, 07:30:24 AM
Run the tube in overnight to let it cook a bit, it's likely just some residual gas that needs to be absorbed by the getter.
Offline calbruc
Reply #3 on: April 19, 2018, 12:15:05 PM
Thanks for the replies.
I'll keep it running over night.
Glad to know it's probably not anything serious!
