Scratching sound when adjusting volume
Kitchener · 2060
Offline Kitchener
    • I made something!
on: April 28, 2018, 12:26:16 PM
I speedballed my Crack a week ago.
I installed a new pot (TKD 2CP-601) a week before that.
After installing the Speedball there has been a slight scratching noise when adjusting the volume on the Crack.
It's barely noticeable on my HD6XX Senns (but much more prominent on my 80 Ohm Beyer DT770s)
Some observations:
The scratching is not constant; only slight stabs of scratching when I twist the pot,
the quicker I twist the louder the scratch,
it goes away after a while.
Is this expected behaviour or indicative of some malady?
Just to go off topic right off the bat:
After speedballing, my 80 Ohm Beyers really stopped playing nice with the Crack.
I notice the bass seemingly dropping off sometimes, like the headphones can't keep up.
This does not happen with the 300 Ohm Senns.
Modded, Speedballed Crack + Sennheiser HD6XX
STAX SRM-353X + SR-L500
STAX SRM-313 + SR-L300
-Jørgen E. J.
Reply #1 on: April 29, 2018, 03:38:37 AM
80 ohm headphones are on the low side for the Crack.
We cannot really help much with an aftermarket volume pot that's noisy.
Offline Kitchener
    • I made something!
Reply #2 on: April 29, 2018, 04:08:28 AM
Yeah totally, I know the Beyers aren’t a good fit at 80 ohms.
Okay, I just figured maybe someone here might have experienced something similar since some of you have been around for a while.
-Jørgen E. J.
Reply #3 on: April 29, 2018, 04:33:30 AM
I've run into some scratchy pots, but usually on equipment that's very old (with crud in the pot).
Offline Kitchener
    • I made something!
Reply #4 on: April 29, 2018, 06:09:05 AM
Some have suggests the pot might be defective.
So I’ll either switch it out with the stock pot or see if the vendor is willing to help out with a replacement.
-Jørgen E. J.
