locate source for manual download for 10 year+ old Seduction phono preamp
dvaugh · 1987
Offline dvaugh
I purchased a Seduction phono preamp as well as the line level preamp of the time online at least ten years ago, I havent a clue what my login
and password were back then and my email has changed several times since. I am having problems with phono playback
and want to attempt to figure out the problem I have my phono preamp manual but cannot locate my linelevel amp manual
the problem I am facing was in one of the two amps since I finished building the set years ago but other then verifying ohms readings and voltages as/per the construction manuals back then I wasnt able to find the problem, so I set the pair aside and
pretty much gave up on the pair. now I am retired and have the time to try and sort the problem out....but I need the documentation to start. Bottlehead while acknowledging that some requests for manuals could be for equip. purchased a long time ago assumes that we have all login info i/e email,password etc used back then. I guess I am the only bottlehead customer
that doesnt keep track of old login info, and they wont let me download these legacy documents without being able to login
to my ancient account.
Does anyone know of a source for bottlehead legacy construction manuals I/E Seduction phono preamp kit
thank you
Duane Vaughan
duanealyzer(at)gmail(doh+)com
« Last Edit: May 18, 2018, 06:44:53 PM by Caucasian Blackplate »
You do need an account to download a manual. But you don't need the account you lost the information for. You can register a new account and then request the manual from Eileen.
Just a note that I scrambled your e-mail a bit to keep the Viagra and time share bots from finding you!
Offline fromnowon
Congratulations!  I think that's awesome that you now have time to work on these projects.  I'm looking forward to that someday.  Good luck!
