221k resistors to bypass Vol and Balance pots?
Metropolis488 · 3400
Offline Metropolis488
on: June 10, 2018, 09:43:59 AM
221k is what I have laying around (would prefer not make an order for 2 resistors if I don’t have to)
Is this value ok?
Also, planning to add them on the outputs on the (the middle lugs) selector switch - put them between red wire’s tab out and it’s respective black and the white and it’s respective black. Then the two black wires directly to 8U and red and white from the selector switch directly lugs 10 and 11. (I hope this makes sense)
Is this an acceptable way to do the bypass on my Stereomour II?
Reply #1 on: June 10, 2018, 01:11:50 PM
Is this value ok?
Sure, that will work.
That will be a pain in the butt.
Put one resistor between 8U and 10U.
Put the other resistor between 11U and 13U.
Reply #2 on: June 10, 2018, 03:11:07 PM
That worked. Thanks!
