Low staticky crackle on right channel (solved)
Julyan9 · 11258
Online Doc B.
Reply #45 on: July 13, 2018, 09:32:57 AM
Oh man, you're giving me flashbacks. I lived in a high rise apartment building when I was in high school in the 70s. I'm remembering the fallout shelter signs in the basement.
Unfortunately it's always harder to diagnose this kind of thing without being able the hear the noise in person. I'm gathering this is a new build? Some times the noise is coming from a tube and may go away as the tube cooks in from several hours of play. Or maybe it's a socket connection. Along with testing the wire connections underneath, have you tried rocking the tubes in the sockets a little to see if that makes the noise come and go? Cleaning the tube pins can sometimes help.
Offline Julyan9
Reply #46 on: July 13, 2018, 08:30:55 PM
Yeah exactly like this!
It is a new build indeed.
I did clean the tube pins but that didn't help. Manipulating the tubes has no effect. Only thing I think affects is when I poke around the red wires on the underside, but there is not 1 place that makes it any more than the other. Its like the whole red path makes it. Or it just happens to crackle at that specific time.
soldered speedball again and voltages improved a bit:
Small board:
OA 70
IA 191
B-A/B 0
IB 190
OB 69
Big board:
OA 106
OB 106
G 0
B+ 193
Edit:/
MAN this amp is baiting me so hard. I was doing reflowing and whatnot, turned the amp over added the tubes and did some more chopstick testing. I hear the same freaking sound again and then I see I forgot to add solder to the connection from hp jack to 6L, I poke the connection and when i press the wire from the middle down with my finger the amp goes dead silent. The quietest I have ever heard it. Im like this is it. The 6L end of the terminal had the wire just go straight to the hole and soldered, so there was no proper physical connection. I went and bent the wire over the terminal and pressed tight, soldered and I was SO HOPEFUL. I power the amp and everything is the same as before. Even the voltages went up the old where they are a bit higher. What are the changes that after I have redone all circuits, swapped wires etc. etc. there would still be a cold solder or a bad wire after the chopstick test has no effect, and I can sometimes make the sound go away with wiggling the small tube, but so I can with wiggling random wires from underneath.
Is there any chance that the 6as7g could be the culprit?
« Last Edit: July 14, 2018, 02:46:37 AM by Julyan9 »
Reply #47 on: July 14, 2018, 03:54:12 AM
I'd let the amp run for 50 hours to see if the tubes cook in.
Offline Julyan9
Reply #48 on: July 14, 2018, 06:43:18 AM
Ill try it! Maybe I just nicked all wires that affect right channel and none of the left channel ones :D I had 1 not that good physical connection on the red wire going from A7 to the potentiometer(I had just weaved the wire through the terminal in the jack but hadn't fold it over.) That didn't do anything. Ill let the amp run now on its own for a while. Do i keep headphones in it and play music or just let it go on its own?
Reply #49 on: July 14, 2018, 06:56:12 AM
You can just let it idle.
If after the 48 hours the noise persists, try to lay hands on a film capacitor that's between 0.1uF and 1uF and rated at 250V.  These are pretty easily found at your local electronics store, and will be handy for another test.
Offline Julyan9
Reply #50 on: July 14, 2018, 07:35:23 AM
I will do that. I really appreciate the time you have taken to try and help me with this issue.
Offline fromnowon
Reply #51 on: July 15, 2018, 03:30:49 AM
Just a side note.  Wow, this support is so impressive.  I can't remember ever seeing this level of support for a product by the developers and designers themselves.  This is great.  I'm having fun following all these Crack builds as I go through mine at a snail's pace.  I just wanted to say it's noticed and appreciated even if not my project directly; you guys are the best.
Online Doc B.
Reply #52 on: July 15, 2018, 06:00:36 AM
Thanks very much for the kind words, we really appreciate it. We figured out years ago that the moment of truth when you start the project up can be the tipping point on whether you get satisfaction from the project. Everyone has to climb the learning curve, and everyone makes mistakes. So that particular moment when something doesn't work right and frustration can start to set in is what we try to be most sensitive to. The kits are designed with this in mind and the layout, and assembly and test procedure reflects the desire to make it as easy as possible to get through the rough bits. Having a place to ask questions is the other important ingredient in the recipe.
With the Crack kit what we want to do is help people learn the basic skills like soldering and using a meter, and deliver a solid design that sounds good. There are plenty of universities teaching electronics theory if you want to climb higher up the curve and become a designer. I like to think we have inspired at least a few customers to head in that direction.
Offline Julyan9
Reply #53 on: July 15, 2018, 06:19:28 AM
I really really want to find the cold solder from the kit but its just so annoying when nothing happens after tens of tries :D
Reply #54 on: July 15, 2018, 08:41:49 AM
We also learn a lot from providing this tech support.  When we revised the Crack 1.0 to the Crack 1.1, almost all of the changes were in response to common trouble spots for the average builder.  As we put out new kits, those changes just keep getting folded into everything.
Offline Julyan9
Reply #55 on: July 15, 2018, 09:33:26 PM
Does it matter which green wire goes to which terminal from and to B7/B8? I think I just kinda winged it since the manual just says to get the wires from 7 and 9 terminals of the transformer to B7/B8
Edit://
So I went to the local store and they only had the one I have attached the picture of. When I got home I remembered that it should have been a film cap instead so that maybe doesn't suit the need here?
If I order this ERO / VISHAY / ROEDERSTEIN MKT 1813 470NF (0.47UF) / 250V (MUSTARD STYLE) POLYESTER FILM CAPACITOR, AXIAL it will be the right one yes?
« Last Edit: July 16, 2018, 03:26:43 AM by Julyan9 »
Reply #56 on: July 16, 2018, 06:17:43 AM
That will work.  Temporarily solder that cap between 1U and 5U, then let us know if the behavior of the static changes.   Be sure to leave the leads super long, as we may end up putting this cap in all sorts of different places as we check each bit of the circuit.
Offline Julyan9
Reply #57 on: July 16, 2018, 07:21:02 AM
1U and 5U was no cigar.
I got some better solder and wick, and I was bored so I went over the red path again, the solders look much better and shinier, but it didn't help with the initial issue. Last solder I had was Sn60Pb39Cu1 and this one is Sn62Pb36Ag2
« Last Edit: July 16, 2018, 08:08:44 AM by Julyan9 »
Reply #58 on: July 16, 2018, 01:39:07 PM
What was no cigar?  Did you get noise only in one channel or in both channels?
Offline Julyan9
Reply #59 on: July 16, 2018, 06:00:57 PM
Same noise on right channel only. I.e. nothing changed
« Last Edit: July 16, 2018, 06:03:34 PM by Julyan9 »
