Pair Crack with a speaker DAC/amp
gbennn · 1763
Offline gbennn
on: July 24, 2018, 05:52:57 AM
Hi every one,
I've been using my HD650 with the Crack and a Schiit Modi 2U as a DAC for a few months now and it's awesome.
I'm currently in the market for a speaker setup and I'm about to buy a Cambridge CXA60 DAC/amp combo with some Focal speakers. The thing is that I would like to merge the 2 setups (use the same DAC for my speakers or my headphones).
The Cambridge amp has a so called 'Pre-out ' RCA output. In the user manual it's written that it is used as a "pre-amp out connection for a power amplifier or active subwoofer" for exemple.
Do you think it is possible to use the DAC of the Cambridge amp then go to the Crack through this 'Pre-out'? And if it's possible will the preamplification for the Cambridge degrade the sound?
I'm a bit confused, I asked on the help thread of r/audiophile and some guy told me it's ok because it's "at line level". I will be very thankful to have your opinion on that.
Ben.
Reply #1 on: July 24, 2018, 08:26:30 AM
Yes, you can connect the preamp output of the Cambridge amp to the Crack. You will have to judge for yourself if it degrades the sound.
