Improve mainline cabling (internal)?
Detailer · 2823
Offline Detailer
on: August 18, 2018, 07:02:32 AM
My Mainline is part of the recent sale so I hope to get it soon.
Looking at the construction I wonder if the power cables can be improved with a fatter gauge or higher copper grade perhaps?
Also would silver plated copper or pure silver signal cables be a bad idea?
I made my silver interconnects which are truly fantastic and am hoping a similar benefit can be had without sibilance or a bad change in character.
Soldering interconnects directly to the internals rather than using plugs seems sensible but I note the shielded connectors and wonder if they help breakup the length as seen by RF emissions.
I understand increased high frequency throughput in gain stages might cause instability.
What I would like to know is where (or if) I can change the cabling to maximise this amps capability.
Since I am investing a lot in this and building it, why not go the whole hog?
Any comments welcome, cheers.
ps
It will be used with HD650 phones (for now) and Holo Spring Level 3 DAC with a modded Singxer SU-1 USB to I2S converter.
I plan on trying the Mainline as a pre-amp on my hifi as well: Emotiva XPA-2 amp, 3 way transmission line bass with ribbon tweeter speakers.  Considering a valve amp on the speakers as they are 91dB/Wm.
Reply #1 on: August 18, 2018, 08:31:29 AM
You're going to have to qualify what you mean by "improved" and what you believe would improve with thicker power cables (which cables are the power cables?).
I would strongly suggest using the wire we provide.  It's actually quite expensive Teflon coated wire for the HV stuff and a carefully selected high bandwidth, heat resistant, shielded Cat5 for low level transmission.  Many who substitute other wire end up with reliability problems and difficulties during the build.
It's sensible until you need a longer cable, want to sell your amp, pull on the cables and accidentally rip part of the internal build apart, or move the cables enough that they break where they pass through the chassis.  There are good reasons that the jacks are there.
This is not a function of the metallurgy of the wire.  The Mainline is a very stable circuit.  Depending on what you use, the wire you select may actually attenuate the high frequencies compared to the cable we provide.
Get some fancy 10uF/250V capacitors and consider stopping there.  When I have had to repair "whole hog" kits like this, it's pretty sad to have to remove all the expensive wire and random parts to put the stock stuff in to get the kit working.
Offline adydula
Reply #2 on: August 18, 2018, 12:40:58 PM
Paul.....I couldnot agree with you more!!
The Mainline just the way it is is world class.....I know many foks want to make things better, but it is already better!!!
One of the finest amps I have ever built or listened with...
Alex
