Cap and resistor upgrades
MikkelR · 2515
Offline MikkelR
on: September 14, 2018, 04:40:21 PM
Hi all,
New here and new to Bottlehead. I bought a used Eros and are looking to upgrade the output coupling caps and the resistors referenced here:
<Snipped>
There's also a 0.1uf cap in the shunt regulator circuit that's potentially worth upgrading.  A 400V cap is OK here.
The 75K 1/2W and and 47K 2W resistors are also very much in the signal path, those could be upgraded, but be sure to use 1% parts or buy enough to match.
<Snipped>
I got matched parts in my drawer and can solder, what I don't have is the manual. I want to make sure I swap the right resistors.I have a decent idea which they are but would appreciate a pointer, especially for the 75K 1/2W's.
Best
/Mikkel
Reply #1 on: September 15, 2018, 06:33:14 AM
You can use a meter to measure the value of most of the resistors in the Eros.
Offline MikkelR
Reply #2 on: September 15, 2018, 07:03:48 AM
Thanks Paul, Absolutely will! Was merely looking for a pointer as to where the 75K 1/2W resistor is located before going over all of them without a diagram  ;D
Reply #3 on: September 15, 2018, 07:11:34 AM
Under the front C4S boards.
Offline MikkelR
Reply #4 on: September 15, 2018, 07:29:02 AM
Got it! Thanks a bunch.
