Hi!
I built my crack around a year and half ago. Around 6 months ago I checked for some cold joints, found some, and properly fixed them. Those are the only changes I've committed to the crack, everything's stock.
Now, around a week ago, while the crack was one for around 5-6 hours, my power went out for 10 seconds, and then turned back on. I turned off the crack once the power came back on, and switched to different headphones w/o an amp for the night and resumed using the crack the day after.
Since then, every now and then, my audio will slow down. Think of a record player/turntable that's spinning and then you turn off the power and the audio starts to slow down until you power it back on.
It'll do this for maybe 4 or 5 seconds. Is there something I can do to fix this?
My audio chain is as follows: Headphones (Senn 6xx's) connect to Crack. Crack inputs go to my Scarlett 2i2. My 2i2 is then usb connected to my PC.
After the power went out, I turned the power switch off on the back of my desktop, unplugged it from the outlet, and held the power button to drain excess power from the desktop for safety measures. Aside from that, I didn't do anything I didn't mention already.
Thank you for your help
