My Build Log (Frustration) [resolved]
Kurjok · 2751
Offline Kurjok
on: November 25, 2018, 05:41:48 PM
I thought I'd start a thread for the many problems I'd encounter. I just started soldering and am already extremely frustrated. I watched the video on how to solder to the power switch without melting it multiple times and I just attempted it but the switch melted before the solder started to flow. I put my iron touching the wire and the lug for around 1 second and tried to solder but it wouldn't flow. So I tried a little longer and it melted. How am I supposed to do this properly? It seems impossible as it's too hot and melts the switch but too cold for solder to flow.
« Last Edit: December 08, 2018, 07:48:03 AM by Paul Birkeland »
Reply #1 on: November 25, 2018, 06:10:18 PM
What kind of solder are you using? What is the iron? How did the five previous solder joints go?
Offline Kurjok
Reply #2 on: November 25, 2018, 06:55:27 PM
I'm using Kester 44 60/40 solder. I have an Aoyue 469 soldering iron. The previous solder joints are shiny and look good from what I can tell. I tried soldering a few cables before I started this project and they turned out well.
« Last Edit: November 25, 2018, 07:33:41 PM by Kurjok »
Reply #3 on: November 26, 2018, 06:27:43 AM
Do you have the iron turned all the way up? (You should)
If the switch melted before the solder flowed, the iron is probably not hot enough.
Offline Kurjok
Reply #4 on: November 26, 2018, 06:53:16 AM
I did not, I had it at 7/9. I will try max when my replacements come in.
Reply #5 on: November 26, 2018, 09:52:48 AM
Make sure the iron tip is well tinned. You might also try very lightly sanding the terminal surfaces of the replacement switch with fine sandpaper or an emery board before you solder them. Sometimes that will help the solder to start flowing over the terminal.
Offline Kurjok
Reply #6 on: December 07, 2018, 02:27:23 PM
My power switches arrived and a tried doing them again with my soldering iron on max and got it! Thank you for the help so far... got another question though. My resistance checks came out right and when I went to test voltage of terminal 4 I got a nice shock. What should I do now?
Offline Kurjok
Reply #7 on: December 07, 2018, 06:25:30 PM
I'm happy to say this will be my last update. I must've accidentally touched the metal when clipping my multimeter to the test connection. Everything tests within ranges. It sounds phenomenal! Worth the shock. Big thank you to everyone who helped!
Offline lyons238
Reply #8 on: January 24, 2019, 04:03:54 AM
yes this is just a soldering mistake on your part. once you get some experience soldering you can easily determine what size tip, temperature, will best suit the joint. then as others have stated, tin the wire, the tab, and the tip of your iron just before attempting to solder. you want to solder quickly, and once you see the joint has turned to a nice shiny joint that's filled in sort of like a small bubble but less so on vertical joints.
also another helpful tip is to use extra flux sometimes if you're not using the correct temp, tip, etc, the extra flux can help flow the solder nicely into a strong joint. I use denatured alcohol and a small brush or q tip to wipe the flux afterward. another tip is to use heat shrink on the ends of the wire to avoid melting the jacket, though this shouldn't be an issue if you have the right equipment, temp and skill but it's still a nice touch.
if you plan to solder a lot I recommend the hakko fx888d soldering station with some different sized genuine hakko tips. this kit is temp controlled and is very high quality and makes soldering a joy.
Reply #9 on: January 24, 2019, 04:25:46 AM
Did you get shocked, or was there a spark?  If you got shocked, what were you touching when it happened?  If you got a spark, you probably slipped and touched the probe on 4 and 3.  Sometimes it's helpful to wrap a piece of tape around all but the very tip of the red probe on your meter.
