Beyer DT990 250 ohm vs 600 ohm on Crack
art12354 · 9213
Offline art12354
on: February 22, 2019, 06:30:23 AM
I currently have the DT990 250ohm, but was wondering if the simple upgrade to a 600ohm would sound any better on the crack
Arthur Sommer
Offline Kristofernak
Reply #1 on: June 06, 2019, 04:38:21 AM
heh, the same question
Offline tim273
Reply #2 on: June 14, 2019, 04:42:55 PM
I have a Crack with Speedball and here's my observations.
While not exactly the same, I have two pairs of the DT770 Pro 250 ohm models and I replaced the drivers of one of them with the 600 ohm drivers (https://www.markertek.com/product/byd-935037/beyerdynamic-935037-600-ohm-headphone-driver).  Since you can't buy the DT770 Premium 600ohm model anymore, and trying to find a pair is next to impossible, I just did "headphone surgery" and created my own version.
Overall I thought it was a worthwhile upgrade. I've read that the DT770 Premium 600 Ohms were bass light, but not in this case, it's all there just like with the 250's and it almost seems like there is a little more bass, but it is more tight and well controlled.   It was subtle, but noticeable.
The only thing I don't like is that they turned into treble cannons in the process, but I ordered Schiit Loki (equalizer) to hopefully help tone that down.  Even though they are treble cannons, the treble is so much more detailed than it was before, it seems like I can hear more separation between instruments and vocals.
It has to do with damping factor, here's a good article on it: https://www.innerfidelity.com/content/comparison-beyerdynamic-dt-880-32-ohm-dt-880-250-ohm-and-dt-880-600-ohm-headphones
Overall the difference was noticeable with the increased level of detail and the tighter bass, but an EQ is needed to tone down the brightness.
Hope that helps.
« Last Edit: July 03, 2019, 04:55:51 PM by tim273 »
