LED A3 to Center Pin not lit
egildernew · 3547
Offline egildernew
on: March 02, 2019, 09:02:28 AM
I built the crack several months ago. Everything seemed to operate fine. I could detect a slight channel imbalance. I replaced the stock potentimeter with a valab 23 stepped attenuator. I also used a 6F8G to 12AU7 tube adapter to run a Tung-Sol USA 6F8G/VT-99.
I noticed the A3 to Centerpin LED was not lighting. I do not know when it stopped working. I just got a speed ball upgrade delivered and would love to install but I am concerned about tracking down the cause of the LED failure. I reinstalled the stock potentiometer and tubes. The A3 LED is still dead.
My current voltages
Terminal: Measured (Expected)
1: 83.5 (50-100)
2: 176.1 (170)
3: 0 (.0001)
4: 176.1 (170)
5: 61.65 (50-100)
6: 0 (0)
7: 109.9 (90-115)
8: 0 (.001)
9: 96.5 (90-115)
10: 0 (0)
My current resistances
Terminal: Resistance
3: 0.1
6: 0.1
7: 3.043
8: 0
9: 2.976
10: 0.1
12: 0.1
14: 0
20: 0
22: 0
B3: 3.043
B6: 2.974
Right RCA: 93
Left RCA: 97.3
Any ideas?
Thank you guys for your time!
« Last Edit: March 02, 2019, 09:13:31 AM by egildernew »
Reply #1 on: March 02, 2019, 10:44:17 AM
Can you carefully measure the DC voltage at A3?
Offline egildernew
Reply #2 on: March 02, 2019, 10:51:48 AM
.937V
Reply #3 on: March 02, 2019, 12:31:43 PM
I'd be interested in seeing photos of the wiring around the 9 pin socket if possible.
Offline egildernew
Reply #4 on: March 02, 2019, 01:39:51 PM
First timer
Reply #5 on: March 02, 2019, 01:45:32 PM
What DC voltage do you get at A2?
Offline egildernew
Reply #6 on: March 02, 2019, 02:08:53 PM
0V
I'm not running anything through it right now.
« Last Edit: March 02, 2019, 02:20:43 PM by egildernew »
Reply #7 on: March 02, 2019, 07:45:59 PM
I suppose it's also worth it to check A1.
62V plate and 0.9V cathode is about 2mA of plate current on the 12AU7 triode curves, but you're drawing 5mA.
Did replacing the pot end up curing your channel imbalance?  Were the voltages looking OK when you built the kit? (And did both socket LEDs illuminate?)
Offline egildernew
Reply #8 on: March 03, 2019, 02:27:46 AM
A1 is 0V
Replacing the pot helped with the channel imbalance.
When it was built both LEDs lit. All the voltages checked out.
« Last Edit: March 03, 2019, 03:50:48 AM by egildernew »
Reply #9 on: March 03, 2019, 05:12:06 AM
Try pulling the 6080 and powering up the amp with just the 12AU7 to see if that changes things much (just measure voltages on terminals 1-5 and note which socket LEDs light).
You are correct that installing the Speedball isn't going to resolve whatever is going on here.
Offline egildernew
Reply #10 on: March 03, 2019, 07:25:50 AM
Voltages with 6080 Pulled
1: 98.4
2: 228.4
3: 0
4: 228.3
5: 75.3
A1: 74.8
A2: 0
A3 1.123
A4 0
Voltages with 6080 in
1: 83.5
2: 176.1
3: 0
4: 176.1
5: 75.3
A1: 61.57
A2: 0
A3: .927
A4: 0
A3 LED still not lit, other LED lit
I am happy with how it sounds. I am just worried something might burn up.
« Last Edit: March 03, 2019, 07:28:19 AM by egildernew »
Reply #11 on: March 03, 2019, 07:43:01 AM
Pull the 12AU7 tube out of the socket. Set your meter to continuity test, or to a very low, like 200ohms, resistance test range.
Measure the resistance of the pins on the 12AU7 tube. Measure from pin 9 to pin 4. It should be very low, just a few ohms.
Then measure the resistance from pin 9 to pin 5. Again the resistance should be very low.
This will verify that the heater in both halves of the dual triode tube is good.
Offline egildernew
Reply #12 on: March 03, 2019, 09:23:21 AM
12AU7 Continuity test
Pin 9 to 4 : 5.7 ohm
Pin 9 to 5:  5.7 ohm
I can see both heaters light up when using the 12AU7. I have an ECC82 and when it is run the A3 led remains dark.
Evan
Reply #13 on: March 03, 2019, 09:58:33 AM
So you have multiple 12AU7 tubes that exhibit this same issue?
Does your meter have a diode test setting?
Offline egildernew
Reply #14 on: March 04, 2019, 08:38:37 AM
I have two 12AU7 tubes, an ECC82, and a 6F8G to 12AU7 tube. They all result in a unlit A3 LED.
I have a Fluke 117. I am not home but I think it has a diode test setting.
