S.E.X. very low hum (think I know what to do..but checking..)
ejb14 · 2204
Offline ejb14
Hello;
I believe this is an "upstream of the S.E.X. amp problem", but would like to check myself with the experts..
With inputs shorted I cannot hear anything with headphones on the S.E.X. with the volume at max - silent. Remove the shorting plugs (so nothing is connected) and I can hear what sounds like a (very faint) 120hz hum. I hear this same hum when the S.E.X. is connected to my preamp, a NAD 1300 that I restored. The cable is an audioquest evergreen cable 1m long.
I did not hear any hum from the solid state amp (a NAD 902) which the S.E.X. has replaced. Admittedly,  the 902 does not have a headphone jack, but I didn't hear anything at the speakers with my ear close to them and the 902 trim controls at max. All components in this topology are connected to an Emotiva power strip that is plugged into a wall socket by itself.
The NADs do not have a ground connector on their plugs - so could be contributing to the issue  - I think I read a post on this forum that I could connect a ground wire to a screw on the S.E.X. back to the NAD preamp and that may resolve it. Just want to be sure this is an ok thing to do - don't want to create an electrical problem that blows up my new amp :); I suspect this could be background noise from some transformer in the topology being picked up by the cable too.
-Ed
This means your amp is not the issue.
Try turning the volume down a bit on the SEX amp, that might help.  This is the SEX amp picking up ambient grunge in your environment.
Same recommendation as above.
Solid state amps have dramatically lower input impedance and a fair number of precautions taken to avoid amplifying environmental noise.  It may be that a 10K resistor across each RCA jack at the input of the SEX amp would replicate this.  It may also be the case that you need to touch a wire between the chassis of your SEX amp and the chassis (grounding post) of the NAD to see if there's some kind of grounding issue.
Well, as the title of your post suggests, you know what to do!
You'll have to do something a lot stranger to cause that kind of damage.
Does the noise get worse if you have the cables plugged into the SEX but not connected on the other end?  (Or try temporarily wrapping a 10K resistor from center pin to shell on each free end to provide a reasonable approximation of being plugged in)
Offline ejb14
Great - thanks Paul - didn't expect a reply back so quickly on the weekend.
Yes, I should have been more clear in my post - this is definitely not a problem with the S.E.X. amp.
RCAs connected to S.E.X and to nothing else - no noise - Also 10k resistor across pin and shield of the free end of RCAs had the same effect - no noise. So I think that rules out that cable. Connect to the RCAs NAD pre - get the noise back.
I'll go through the process of tracking it down when I have a little more time today. I'll try the ground wire trick - but I would like to know who the culprit is too. I will start with disconnecting everything (have a number of items plugged into it) from the NAD and slowly, one at a time, building the chain back up until I find the culprit. Probably the NAD pre itself - in which case I'll figure that out pretty quick when I disconnect everything from it. I'll post again when I find it.
Sorry to bug you. It's Sunday and you guys are great - love the support - but - don't you get a day off from bozo's like me playing electronics?
Thanks again!
-Ed
The grounding wire between the chassis panels of the NAD and the SEX will probably work in your case.
