Random shut off
mishak · 1688
Offline mishak
on: April 14, 2019, 12:48:00 PM
So I just finished building my crack amplifier.  All the resistance checks and voltages checked out.  I got it fired up and it was working great, for about 20 minutes.  Then out of no where, the amplifier shut off and I haven't been able to get it to turn back on.  Everything seems ok when I look under the hood.  I am very new to this, and this was my first DIY project.  Any help on where even to start would be appreciated!  Thanks.
Mark
Offline borism
Reply #1 on: April 14, 2019, 01:07:16 PM
Did you check the fuse?
Boris
Reply #2 on: April 15, 2019, 05:09:34 AM
Yes, check the fuse and if it is OK then go back and take new resistance measurements. One possible scenario is that a solder joint was missed and lost contact as the amp warmed up. That might show up as a bad resistance reading somewhere. Let us know your result.
