Page 30, soldering B7 and B8 (resolved)
R-Oak · 1972
Offline R-Oak
on: May 03, 2019, 08:34:55 AM
Sorry a second question
On page 30, it is said to: keeping the twisted wires close to the chassis, attach one wire to B7 and the other to B8
Question : B7 and B8 have 2 holes each, sooooo do i attach it to Lower B7 and Lower B8 ???
Second images and task says : to add more wire to B7 and B8 and now solder ...
Question : so I will have 2 wires in B7 and 2 wires in B8 before I solder ...
 Is it one in each holes ?
Is it both in one holes and solder only that one ?
Is it one in both holes but still solder both ?
I'm guessing I'm just putting both in the same hole and solder that one hole, and leaving the second one untouched
Again, I'm really sorry for a question that might seems easy reading the guide, but I'm REALLY trying to do no mistakes
Thanks alot !!!
« Last Edit: May 05, 2019, 05:48:30 PM by R-Oak »
Reply #1 on: May 03, 2019, 09:22:16 AM
For ease of installation and any future modifications, I suggest you attach the first pair to the lower holes, and the second pair to the upper holes. This is the way it is done in the manual -- if you expand the images on your computer/phone, you can see this.
[Edit: but if you've already attached them in one of the other ways, that will work just fine. Any of the three ways will acheive the same wiring connections]
cheers,
Derek
« Last Edit: May 03, 2019, 09:30:50 AM by Deke609 »
