Speedball D1 & D2 dark - Resolved
phigits · 2120
Offline phigits
on: May 17, 2019, 03:33:32 PM
Meter readings
OA - 69
OB - 40
G - 0
B+ - 79
D1 and D2 LEDs are dark.
The small board readings were fine before the large board was fitted.  Now they are:
OA - 42
1A - 78
B-A/B - 0
IB - 78
OB - 69
I don't see anything obvious so I'm hoping someone can point me in the right direction.
« Last Edit: May 18, 2019, 10:11:46 AM by phigits »
Reply #1 on: May 17, 2019, 04:06:57 PM
Your TIP50 transistors are improperly mounted and shorting out the HV supply.  Please see the note in enormous text on page 22 and also note that we have a link to a video because it is so critical that these steps are followed carefully.
I would also very, very strongly suspect that you have a PN2907 in backwards on the small board.
Offline phigits
Reply #2 on: May 17, 2019, 05:17:47 PM
Damn.  100% ass-backwards on the TIP50's.  Both PN2907 are correct.
Ordering new parts.
Thanks, Paul.
« Last Edit: May 17, 2019, 05:20:46 PM by phigits »
Offline phigits
Reply #3 on: May 17, 2019, 05:42:08 PM
Wait a minute...the TIP50 transistors look correct.  But I see the D1 and D2 LEDs are upside down...
« Last Edit: May 17, 2019, 05:44:41 PM by phigits »
Reply #4 on: May 17, 2019, 06:00:28 PM
Maybe post a pic or two of the board just to be sure.  Fresh eyes are better at picking out possible problems.
cheers,
Derek
Offline phigits
Reply #5 on: May 18, 2019, 08:39:56 AM
The LEDs and voltages are ok.  Now I'm just chasing down a buzz in the right channel.  Checking all the joints again.
Offline phigits
Reply #6 on: May 18, 2019, 10:11:10 AM
Found a post from PB where he repaired a buzz in one channel by removing excess solder from the center pin of the RCA jack.  I did that and viola, the buzz is gone.
